Question about RCA RCR450 Remote Control
Remote code for my ge universal remote
I need a remote code for my ge remot model rc24912-dfor a sharp tv
  • Anonymous Mar 23, 2014
    I need the three code for a ge universal control
  • 95 Answers
This is the quickest and easiest way to program your remote: To program a component using the Automatic Code Search method, perform the following steps: 1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. remote code for my ge universal remote - info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF The illuminated ON-OFF button turns off. 4. After the illuminated ONremote code for my ge universal remote - info.gifan> button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under thremote code for my ge universal remote - aud_remote_play.gif is retained. 5. Press and release the PLAY button. aud_remote_play.gif 6. If, after fiveremote code for my ge universal remote - info.gif, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search remote code for my ge universal remote - info.gifthod is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconremote code for my ge universal remote - aud_remote_reverse.gif turns on again. This will isolate the correremote code for my ge universal remote - info.gifin the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. aud_remote_reverse.gif info.gif If the REVERSE button is accremote code for my ge universal remote - aud_remote_stop.giffter the component responds, press and relearemote code for my ge universal remote - info.gifspan>FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button. aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s functions.
Copy of manual below as well
http://support.rcaaccessories.com/doc/Device_Documents/manuals/RCR450_manual.pdf?deviceDocId=216&docid=959&docid=983&navtypeid=6&pagetypeid=7&prevPageIndex=31&selectedmodel=RCR450&selectedFamily=generic&nvty=m
Posted on Mar 16, 2008
Hello and if you think the guy above me is too confusing then use my shorter version of what he is tring to say.
1.Press and hold both the tv and ON-OFF button
2.Press and release the PLAY button. If after five seconds, the component does not respond,
continue to press the PLAY button every five seconds until it turns off
3.When the component turns off, press and release the REVERSE button, then wait two seconds
to see if the If the component does not respond, continue to press the REVERSE button
every two seconds until the component turns on again.
4.press and release the STOP button. to save the program
..really is it that hard to say this
Posted on Dec 08, 2008
  • tvkid Dec 08, 2008
    This is the quickest and easiest way to program your remote: To program a component using the Automatic Code Search method, perform the following steps: 1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. The illuminated ON-OFF button turns on and remains on.
    3. Press and hold both the component and ON-OFF buttons. The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button. 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button. If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s functions.
    http://support.rcaaccessories.com/doc/De...
    ignore the other comments i have made below and the wierd confusing guy.here is my version of a manual
Code for remote universal tv control
i need the code for tv set jvc for the rc24912-e
Apr 15, 2009 | GE JASRM24912 Remote Control
Lost code for my ge remote model # rc24912-b
heres all the codes for that tv one of them should workSYLVANIA ................ 0062 0004 0009
................. 0135 0189 0183 0227 0456
................. 0008 0068 0075 0141 0161
Jan 21, 2009 | GE RM24912 Universal Remote Control
I have a GE universal remote. Model RC24912-C1621. My tv is a Symphonic.I need the code
you can find all remote codes here
http://www.jascoproducts.com/support/universal-remote-codes.asp
Dec 25, 2008 | Directed 434MHZ Remote Control
Need codes to the remote for a Sharp TV.
look under remote manuals rca, radioshack, it will lists for tvs vcr ect.
Dec 17, 2008 | Gemini 1 Device Universal Television...
AKAI TV WITH J&E RC24912-D UNIVERSAL REMOTE FOR AKAI TV NEED CODE
The codes for AKAI TVs, according to the manual, are 003, 177, 195, 201, 202, 295
Nov 03, 2008 | GE JASRM24912 Remote Control
Need code for sylvania tv
no prob man here ya go, 0030, 0054, 0171, 1944, 1963
Jun 28, 2008 | GE RM24912 Universal Remote Control
Remote control codes
I can't find the codes either, I'm just going to have to buy a new one.
Mar 01, 2008 | GE JASRM24912 Remote Control
Ge universal remote rc24912-c
guamboy1,
Here's a link that should get you everything you need...
http://www.remotecodelist.com/remotes/
Bill
Nov 20, 2007 | GE RM24911 Remote Control
RCA RCR450 Remote Control Logo
997 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
