Question about Altec Lansing 621 Computer Speakers
Altec lansing i need a spare part for my altec lansing and i cant find it anywhere. any ideas?? its a volume controller for a altec lansing 621
I had the same problem. After numerous calls to Altec Lansing they sent me out a new one. The new one doesn't have the same connector on it. I called tech support only to hear that they discontinued the 621 and don't make parts for it. Sorry, you are probably out of luck.
Posted on Jul 31, 2008
SOURCE:
How to take apart altec lansing speakers to clean volume control
You do not take speakers apart to clean a volume control Do you know what you are talking about? I do not think so.
Mar 31, 2017 | Altec Lansing Audio Players & Recorders
My problem is when i turn up the volume of the speaker it will just turn off. tnx
Your altec lansing need to be open, because it has a loss connection on the power supply part of its circuit board. that is why when you turn up the volume it turns off because it produces vibration enough to shake the circuit board which has a loss connection.
1. Prepare the following tools:
* soldering gun/iron / soldering lead and a magnifying glass
* open your altec lansing cover enough to see the circuit board
2. Try to examine the leads on the circuit board, try to share some of the spare parts make sure it is not plug to live outlet to avoid electric shock.
3. if you see some spare parts shaking try to resolder it.
4. Then close back the cover.
5. Then test your altec lansing
Jul 11, 2011 | Altec Lansing ACS 45.1 Computer Speakers
I recently found some awesome altec lansing speakers with a huge sub too. but ... i can't find the volume control knob and without that, i can't make it work !! T___T any solutions? i tried looking for...
Hi there, by saying you found, do you mean that is a complete set, I have the same speaker set, and the volume control knob is on one of the satellite speaker. If you are missing that speaker I doubt that you can do anything with it because you will most likely find them for sale as a set and not separate. Thanks hope this helps.
Mar 09, 2011 | Altec Lansing ATP 3W Computer Speakers
Lost my fuse + fuse cap for altec Lansing 621 during a move, does anyone know a place to get one and part #? I would assume they are still using the same fuse cap and fuse in most their other models so if...
Most fuse holders tend to be STANDARD sizes with regard to mounting holes and fuse sizes
Your idea of going to radio shack is the best as the ones they stock are also STANDARD and even though you may end up buying the whole fuse holder just to get the cap the cheap prices would be worth it.
If worst comes to worst you would have a WHOLE holder to replace the one that is in there if you dont mind doing a little soldering.
http://www.parts-express.com/wizards/searchResults.cfm?FTR=fuse+holder&search_type=main&WebPage_ID=3&searchFilter=fuse+holder
Mar 23, 2010 | Altec Lansing 621 Computer Speakers
Low volume on Altec Lansing 4.1 system
if the volume controls of the speaker is set to 100% together with the volume control on your computer then still get a low volume,try some other device where you can use your speaker like mp4,if still got same problem,bring it to a service center there might have a problem with the amplifier.
Sep 10, 2009 | Altec Lansing Multimedia Computer Speakers
Cannot ajust volume
adjust the volume through computer audio properties
Feb 22, 2009 | Altec Lansing 621 Computer Speakers
Altec Lansing 621 Problem - pls help
sell me the remote controller. junk the system and get the 5100
Jun 10, 2008 | Altec Lansing 621 Computer Speakers
Altec lansing ada 745
need to check your control center,then if thats not the one"it should be set @ 3/4 volume....
if no diff,,,,,then you need to go over checking every program that shares it,,,has their own volume control,,,somewhere there is the problem,,,maybe real player,,,media player,,,flash player etc...
thnks ttyl
Polywoggy1@hotmail.com..
Mar 10, 2008 | Altec Lansing Multimedia Computer Speakers
AVS500 altec lansing speakers
Here is the link to the product manual. Hope this helps. :}
http://www.altecmm.com/downloads/LAT/AVS500B%20manual.pdf
There is a wiring diagram in it.
Nov 23, 2007 | Altec Lansing 621 Computer Speakers
Altec Lansing 621 Computer Speakers Logo
897 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
Joaquim Martins
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
