Upon trying to start, the engine turns as if the battery is dead. It is a new battery. If I remove the spark plug and turn it over, it turn fine. When I re-insert the plug, it again turn over as if the batter is dead. HELP!!!!
SOURCE: Put battery cables on wrong
For starters remove the battery and take it back to the store where you bought it and have them test it. Your solution may be to purchase another battery.
SOURCE: PLEASE HELP! My husband is driving me crazy about Riding Mower
Sounds like the gear on top of the starter is stuck or broken. Inspect starter. If it's broken, the starter must be removed to replace the starter drive. You may need to buy a Starter Drive Kit. If you starter has a flat piece on top held on by a retaining ring, it's part # 696541. If you have the older type starter with roll pin holding the drive on, you need part # 696540. You probably have the first one. To install the retaining ring, use a 3/8 socket to tap it into the groove. Dwain
SOURCE: I was using my Bolens riding mower and stopped to
sounds like to me that your flywheel key is jammed. you will half to take it apart. Inside you will see a little gear on top of a cylinder shape object. and the gear turns the middle part. you will have to turn the middle part as hard as you can to get the gears unjammed.
if anti back fire selonoid is disconnected how
are you getting fuel? if so ck selonoid again make sure it is open. should run
SOURCE: I have an ariens Fairway model riding mower won't start
DISCONNECT THE SAFTEY SWITCHES FROM THE ENGINE STOP SW. MAKE SURE THE ENGINE HAS SPARK.THEN DO PROCESS OF ELIMANTION
Testimonial: "This is exactly what I did and found the clutch safety switch was sticking closed.Thanks a lot for your suggestion and help."
