Question about Minolta Di152 Laser Printer
Meter reading cannot find meter count button
  • Minolta Master
  • 1,113 Answers
Not sure of your model but ussally can be found on the status/config page print out via menu on printer keypad
Posted on Oct 26, 2007
SOURCE:
How do i get an event log on bizhub250?
No such item. must use the meter count meter. if so some one use the machine. did you use the had count meter or the one on the screen hard count is inside toner cover
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 07, 2016 | Konica Minolta bizhub 250 All-In-One Laser...
How to reset counter workcentre 6505dn?
Try this link:
Read the Billing Meter The total number of printed pages can be reviewed at the Printer Control Panel, on the Configuration Page, and in CentreWare Internet Services (CWIS).
Three meters are available:
  • Total Impressions
  • Color Impressions
  • Black Impressions
The billing meter counts the number of pages that were printed properly.
  • 1-sided prints, including N-up, are counted as one impression.
  • 2-sided prints, including N-up, are counted as two.
    NOTE: During 2-sided printing, if an error occurs after one side is printed properly, it is counted as one.
  • Color documents converted using an ICC profile on applications with the Color (Auto) setting can print in color, even if displayed in black and white. The data prints in color even if it seems to be black and white data on the Display Screen. In that case, the number of Color Impressions is increased.
    NOTE: Grayscale images printed with the composite black setting count as color pages because color consumables are used. Composite black is the default setting on most printers.
  • When printing automatic 2-sided printing, a blank page can be inserted automatically depending on the settings in the application. In this case, the blank page is counted as one page.
View the Billing Meters:
IMPORTANT: The Bill Meters track the total number of pages printed for the life of the printer; it cannot be reset.
To view the total number of pages printed:
  1. Press the [System] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until "Billing Meters" is selected, and then press the [OK] button. The Print Volume Report will be printed.
  3. Press the [Down] arrow button to scroll to the required meter. The number of printed pages is displayed below the name.
  4. Press the [Return] button to exit the Billing Meters menu.
http://wss.support.xerox.com/GTConnect/UnifiedAcceptor/AddWebFramework.Main/site/XeroxProductSupport/product/product_wc6505/lang/en-US/region/region_US/source/DND/Xlang/en_US/Xcntry/USA/prodID/WC6505/KBlang/en/#!view-content/ViewContent/View/contentId/x_6130_en-O8884
Jun 13, 2014 | Xerox WorkCentre 6505/N Multifunction...
How do i find the w&b numbers to input for my monthly meter reading?
User tools button then counter then select print counter that will give black and white total count use that number
May 31, 2014 | Ricoh Aficio MP-201 Copier w/ Duplex...
How do I read the meter on a Canon 3025 copier/
Hello colleenm,
The button that will display your meter is located on the operator control panel that is at your fingertips. Locate the large green START button. At about the 2 o'clock postion to the START button is the STOP button, orange colored. Now look "slightly higher and slightly to the right " and you will see a small "Counter Check" buton. Press it and the meters will be displayed. You will see at the top of the list a meter labeled "101".That meter tells you how many sheets of paper have successfully exited the copier regardless of the size of the paper. My company asks that we set the devices up so that they count 11x17 paper as 2 counts as it is basically 2 sheets of paper. The meters that will be listed below meter 101 are usually unused unless a technician has customized the meters that reside there as we do. I hope this helps. If it does , please let FIXYA know. :-) SPINAL
May 13, 2011 | Canon ImageRunner 3025 Black and White...
Where is meter reading on canon imageRunner C5180i color copier?
Hi sophie,
Look to the far right of the operator contol panel, past the 9 key pad and you will see a "little button" called COUNTER check. Press it and it will tell you your meter reading.This screen can be configured "by a service tech" to allow you to view the count of up tp 6 different meter counts depending on the function you wish to monitor. The basic meter reading is named "101". That because there are hundreds of funtions that are always monitored and they name them 101,102,103 etc. 101 counts the number of sheets of paper that have exited the copier. "102" does the same except it counts 11x17 [ledger] as 2 copies as 11x17 is really 2 letter size sheets. So my company uses this meter for billing purposes so we ADD the 102 meter to the list of viewable meters. Again this can be configured to the customers needs or the service provider needs. You can set it to view just black and white, just color, or even how many copies were made at 64%. its wild. But the 101 meter is the default and cannot be removed or altered. I sure how I helped you. Please let "FIXYA" know.The pat me on the head when I do good. :-) Take care . SPINAL
Jan 28, 2011 | Canon imageRUNNER C5180i Color Copier
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
Printed pages count
on the 416, click on the "machine status" button next to the lcd screen. scroll down to number 09, which is "Total Print Counter".
Nov 28, 2009 | Xerox WorkCentre Pro 416DC Copier
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
Apr 19, 2009 | Xerox WorkCentre M15i Laser Printer
Where to read the meter count?
Open the front door of the copier, look on the inside pannel of the copier, it should be right above the fixing unit.... Good Luck
Apr 01, 2009 | Canon Office Equipment & Supplies
Copy count
You should be able to get the meter reading on a 7022 by pressing the star key (*) on the numeric keypad.
Hope this Helps
May 12, 2008 | Office Equipment & Supplies
Minolta Di152 Laser Printer Logo
117 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
