Question about Compaq Presario 1692 Notebook
Works on external monitor, but not on internal
My 1692 works fine on an external monitor.
however, the internal display does not work.  instead, i see either a blank white screen or blue vertical lines.
is it possible that this is a motherboard problem?  or would the fact that i can see it on an external screen overrule the motherboard issue?
if so, then the problem must be with the screen itself or the screen cable?
what do you think?
  • mikediamond Oct 26, 2007
    i just bought a new 'internal' monitor, and it is guaranteed to work.  What else could the problem be?  The internal cable looks fine, but if i wiggle it, then the vertical lines jump around.
  • john h Sep 26, 2013
    Try replacing your inverter it is located just under the screen when you take the trim off.
I think you must to change your LCD SCREEN or you use a crt display.Your motherboard is ok.
I've another problem, it's a video display. in Dos mode i have a half of screen and i can't use my
laptop under Windows but it's work fine with Linux.
I'd like to know if you have the bios for this laptop, i'm looking for this for a long time ! (not found on hp web site).
If yes please can you send it to me at this email: cyberphone95@hotmail.com.
Many Thanks,
Posted on Feb 27, 2008
  • 38 Answers
You graphics chip/card may be loose or the connections are loose
Posted on Oct 26, 2007
  • 1,006 Answers
No it's not motherboard problem u have to change monitor!!!
Connecting from laptop to tv wont work now. It was working fine previously
Check the display settings on your laptop to see if the external monitor output is disabled. There is usually a function key on the keyboard with a picture of a monitor on it which can be used to switch between internal & external monitors.
You may also need to try on another monitor/TV or change the HDMI lead.
Sep 27, 2012 | pcb Advent 5711 5431 Laptop M/b U41iix...
Part of the screen stays white in my nc150 netbook Looks like it's a left 1/3 of the screen is always white with some thin black and white vertical stripes but the rest of it works fine. I would like...
Paul -
This absolutely could be the ribbon cable connecting your screen to your motherboard. If you know how to check this, it would be worth trying before spending $150+ on an LCD. Any way you look at it, this is definitely a hardware issue. Just hope it's not the motherboard's onboard video card. Here is a modified answer I gave to a question similar to your issue:
If you turn on your laptop and the display is bad, your issue is with either the LCD screen or the motherboard (since the video card is built-in the motherboard). This will be easy to diagnose.
1.) Plug an external monitor (one which you know works) into the VGA port of your laptop.
2.) Turn on the laptop.
3.) Hold down the FN key (lower-left corner of the keyboard) and press the "CRT/LCD" key (it will be located on the number keys or F1-F12. You do this to tell the laptop that it needs to send the video signal to the external monitor instead of its built-in LCD screen.
If the display is good on the external monitor, then the issue is with the laptop's LCD screen (about $200 for the part plus labor to install). If the display is still messed up on the external monitor, then your problem is with the motherboard ($300-$500 for the part plus a lot in labor cost for installation).
Let me know if this helps you!
Sep 30, 2011 | Computers & Internet
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
When I open my computer, I get a white screen. What is the best of fix this?
Buy a new computer from the sound of it, or take it to a repairer, if the screen is white instantly after power on, there is noting that you can do yourself.
May 23, 2011 | Acer Aspire 5742Z-4200 Notebook
The computer works but I have a blank screen, it works when I hook it up to another monitor.
Have you tried pressing and holding the "Fn" key and then, while still holding the "Fn" key, press the "F4" key? This toggles between the internal and external displays. There are three settings. The internal LCD only, both internal and external displays at the same time and external display only.
Jan 03, 2010 | HP Pavilion dv9000z Notebook
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
Montor shows a blank white screen and is unresponsive
Please try to connect the monitor to another PC, if it continues to happen, then probably an internal electronic part/s of your monitor is cold soldered / defective which failed to send signal to other hardware parts of your monitor thus you only see white display. I suggest to bring the unit to an authorized service center fix / replace the cold soldered / defective part/s. regards
May 28, 2009 | Dell Computers & Internet
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
May 29, 2008 | Dell Inspiron 8500 Notebook
I own a evo n510c
If you are hooked up the the external monitor and/or TV and can see the desktop, you can probably reselect the internal display via software from Display Properties.
In most cases you can change from the external display to the internal and vice versa by holding down the blue Fn key, and hitting the proper number on the keyboard. The correct key has a blue icon meant to resemble a monitor on it.
This is if the repair/replacment of the internal screen was done correctly and the screen is actually working. If the screen is not actually working, though, this will not help you.
Jan 28, 2008 | Compaq Evo N610C Notebook
Compaq Presario 1692 Notebook Logo
187 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
