Question about Panasonic PT-47WX42 47" Rear Projection Television
The screen blew off my TV and into a million pieces while moving
I Was moving my tv and the screen on the TV Blew into a million pieces SO I need a new on. Do you have any Idea what the part # is or is it even called a screen? Where can I get one
I don't know what kind of t.v. you have but we have a panasonic 52 inch rear projection t.v. and when we bought it ( used) the one of the screens ( the outer - lenticular screen ) was torn and we had to replace it. Our T.v. has two screens and outer and an inner screen. The inner is more expensive. We used a company called Vance Baldwin and they were the most reasonable. We dealt with a man by the name of Odie Mills and the main office is in Fort Lauderdale Florida. The address is : Vance Baldwin, Inc. 7060 State Road 84 #12, Fort Lauderdale, Fl 33317 (954) 723-9191. Ask if they have a warehouse that deals with their products near you and you might be able to pick up the screen instead of having it shipped to your home. Be sure to check the screen before you take it though, we seemed to have a problem with damaged goods because the screen is so delicate. We ended up just having it shipped to our home and it was packed real well and didn't have a problem. I hope this helps in some way. Melinda
Posted on Dec 09, 2007
My mitsubishi tv started out with white dots on the screen.eventullay i heard a sizzle and pop and the tv went out. so i did research found that i needed to replace the dlp chip which i did and the la
Most likely a fuse blew when the lamp blew, there is internal fuses on the power supply board on these mitsubishi's, if the fuse is ok though then most likely another component somewhere failed.
Jan 02, 2018 | Mitsubishi WD Televison & Video
Can i buy a replacement screen for the front?
try contacting the manufacturer. without more information about the make and model that's the best I can offer.
Feb 02, 2018 | Panasonic PT-53WX42 53" Rear Projection...
Can i buy just the screen for my 61' sony projector tv and where i moved my tv via bed of my truck on freeway about 85 mph and blew plexy glass off front of tv and the outer screen can i buy these...
A Sony dealer may be able to aquire them for you. They are very expensive, so be warned.
Contact Sony's web site for a list of dealers.
Hope this helps.
Nov 27, 2010 | Sony Televison & Video
Blue dots appearing on screen n bulb blew twice
IT NEEDS A LIGHT ENGINE. COST A LOT TO REPAIR.
Oct 06, 2009 | Televison & Video
I was watching TV and it just cut off. There is no power light on and the outlets are working and the cord is firmly in.
good day sir/maam, chances are yout tv just blew a fuse, when a fuse blew up, there are several reasons.
  • It protects your tv from further damage.
  • a part of your tv got bad, causing it to blew.
You have a choice of calling your service center/dealer or do it your own.
If you decide to do it yourself, these are the steps you may need to do.
  1. Open the TV's back cover, to access the circuit. locate the blowned fuse.
  2. you may need to pull out the entire board, to test it.
  3. test the switching regulator IC/transistor for shorts, (you may need a multitester).
  4. check for open low value resistors, less than 100 ohms.
  5. You really need to find the cause of the blew up fuse. part by part checking is necessary,
  6. replace the bad parts and test again.
  7. if everthing else fails, you really need to call your service.
note: if you simply replace the fuse without tracing the blew up shorted bad part, chances are the fuse may blew again.
Oct 02, 2009 | Vizio L32 32 in. LCD HDTV
I moved my tv to a friends house while i moved. we turned it on without leaving it get to room temp. think i blew a picture tube how do i detect this and how much is it to be replaced and also what parts...
picture tubes do not "blow" go bad by going dark check your circuit board for fuses test them and, replace the bad ones as your high voltage circuit is what lights up your tv tube... tv tubes do go bad when they do they show "blooming" and, bad ion masking not a black screen unless the tv is a newer lcd / plasma screen then just replace the inverter board or, cold cathode
Apr 26, 2009 | Televison & Video
TV blew out
if the lamp light is flashing u need to replace the lamp. u should have instructions on the set or in the manual
Dec 07, 2008 | Televison & Video
Older model Magnavox Big screen tv
Sorry Bud... It is dead, and would cost more to fix it then to buy a new one. And even if you got it fixed, something else will blow out on ya before to long, and most of those old parts are no longer made. Hey- it had a good long run of it's life, it's time to let go.
May 30, 2017 | Televison & Video
Panasonic PT-47WX42 47" Rear Projection Television Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
