Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishes are molding that are left in dishwasher before cleaning
The dishwasher is only 1 year old, and recently the dishes left in the washer prior to being cleaned are growing mold within a day. This did not happen until recently, and had never been a problem before.
Also, quite a bit of residue is visible on the stainless steel below the rinse and detergent areas.
  • albigensian Oct 19, 2008
    SAME PROBLEM with my Bosch. Repairman said, "run some white vingear through to keep the line clean. It must be clogging up." Have done so, but problem continues. Standing water is stagnant water -- hence, the mold problem.
    Never had this problem with my prior, cheap dishwasher.
  • 58 Answers
Thats sounds normal except the molding i never herd of b4
Posted on Oct 31, 2007
SOURCE:
Mildew in washer
Hi Meredith, this is AP!
I understand you are struggling with mold spreading in your Frigidaire dishwasher, model PLD2560LCC. The average useful life of a dishwasher is about 13 years, so I would attempt to get a few more years from the dishwasher if you can. Chlorine bleach kills mold and helps remove most mildew stains. Dilute 1 cup of bleach in a gallon of water and scrub the interior of the machine with a stiff brush. Use a toothbrush to get in narrow areas, such as around door gaskets. Wear gloves to protect your hands when you use bleach, and also avoid mixing bleach with any other cleaning product. Run the dishwasher empty after cleaning it to rinse out the bleach residue. If stains remain after mold removal, scrub them away gently with a damp rag and mild scouring powder.
Or you could run a cycle with no dishes. Once the dishwasher has completed its initial fill, add 1 cup of white vinegar and complete the cycle. If you find that removes the mold I would open the dishwasher door after each use and allow it to dry out completely before closing it to prevent mold growth. Moisture, bits of food and a warm environment can lead to unwanted mold growth. If you won't be using the dishwasher for a while, such as when leaving for vacation, leave the door open while you are gone to ensure no trapped moisture leads to a mold or mildew problem.
I hope this information proves helpful to you, thank you for the post.
Thanks,
Mar 29, 2014 | Frigidaire 24 in. PLD2560LCC Energy...
Frigidaire built in dishwasher model PLD2855RFC1. Have to wash dishes pretty much spotless prior to using dishwaser. Glasses come out with what appears to be soap residue regardless if powder or liquid....
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
May 31, 2010 | Frigidaire PLD2855RFC Dishwasher
Our LG Dishwasher is less than one year old and the dishes that are left in it for a couple of days before it gets full enough to wash a load get mold on them
mold grows in warm moist places and the food scraps makes a great petri dish to grow your science experiment its normal during summer season in the cooler season fall winter early spring takes longer
Oct 06, 2009 | LG LDF6920 24 in. Built-in Dishwasher
Mold grows on dishes in bosch dishwasher
Put a bowl filled with 2 cups of clorox on the lower rack and run a wash cycle (nothing else in the machine) this will kill the mold spores in the machine, and clear the smell.
Jul 29, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Not enough water Pressure to clean dishes, 6yr old Bosch
Replace the pump, if you go through the trouble of repairing the pump and all the disassembly and then more problems will probably ensue. As far as location it is usually located under the washer. Accessed through the front service panel. Make sure you follow all safety procedures #1 being unplug the washer or turn off breaker prior to proceeding.
Feb 13, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishes won't come clean
If you have dishes (typically cutting boards or really tall dishes) that block the dispenser door from opening, the water cannot wash out all the detergent during the wash cycle. Check to see that after loading the dishes, your detergent door has clearance.
Aug 26, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Wont clean dishes
Check to see if the Upper and lower spin arms rotate easy .. check to see if there is anything blocking them.. also check the venturi assembly (the tower is in the center of the lower spray arm} As it is what supplies the upper spay arm. let me know if this helps?
Mar 06, 2007 | Zanussi 24 in. DA6141 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
664 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
