Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Fan continues to run after desired heat is established , I blew out the line at pilot and the unit is taking 10 to 15 mins for fan to cut off
Carrier natural gas unit
last night it continued to run fan but no heat for about 30 minitues
but today I found that the pilot was so I blew out the gas line at the pilot and relit pilot it heats up and runs but when I cut thermostat down it takes  10 to 15 minutes for the fan to cut off
  • Carrier Master
  • 4,655 Answers
Looks like your fan limit switch may be bad. It fits into the warm air side of the furnace. It tells the fan to come one and off when the heat is blowing over the limit switch. Now if that limit is defective it also will affect the lighting of your heater being it electronic ig-niter or just common thermocouple type controlled pilot light. Now above your post I think the wong information was given about your gas heater, so giving you the exact information will be difficult. Now from hearing you explanation of the problems, I hope my information was a help to you, Thanks Sea Breeze
Posted on Oct 29, 2007
I have a carrier 48nlx024 I replaced the fan control board and the fan comes on by itself when t stat is off
Do you have a "circ" feature on your tstat? This will periodically bring the fan on to circulate air. Be sure you are on auto. Is the fan running continuously? Possibly have relay backwards.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 02, 2017 | Carrier Heating & Cooling
How do you check a fan motor
You need to check the volts at the motor while it's running, to make sure some safety is not shutting it off. Then check the amps on the motor while it's running. Also you need to check your capacitor and wiring.
Apr 30, 2014 | Heating & Cooling
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Error code 3
bad fan motor or compressor
Nov 08, 2017 | Carrier 38CKC036 Air Conditioner
Brivis Upflow/Downflow fan on continuously, no heat
depending on the year of the unit
if its between 1992-1999 it would be caused by the either the pilot not staying alight, or a faulty gas valve not opening,
These models start the fan on a time delay not tempreture so you will only get cold air circulating and when the thermostat is off the fan will stop.
(All models) if the fan is running regardless of the thermostat position an over heat sensor is faulty.
May 17, 2010 | Heating & Cooling
I have a technical question regarding implementation of my Carrier furnace within my residence. Specifically, the furnance has been installed for 17 years and I have not had any problems with it. I have...
Thats a safety.
The unit senses a failure to ignite, so it goes into safety mode keeping the blower running to prevent overheating and fires. And keeping the inducer motor running to prevent the same, as well as raw gas build up inside the unit.
The newer systems are "smarter" and can detect more specific problems and failures. The older ones simply know that the thing didn't light, so they bring on the fans for safety.
Jan 01, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have two ptac units, both want to run 5 or 6 mins. and cut off
Make sure there is nothing in front of the units, Chair, Couch ect, if you take the cover off the Units, you will see a little black Thermoster attached to the coil.
If the air bounces back off of something then it will cool that Thermoster and shut the unit down before the desired room temp is acualy reached.
Also make sure your Thermastat control knob is turned far enough to the right so that its asking for more cooling, Or desired temp.
Hope this helps.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Oct 26, 2009 | GE Zoneline Deluxe Series Cooling &...
Blower fan runs continually with the thermostat removed or installed. This is a older carrier combined unit with a furnace. Control board installed is a HH84AA 011. Replaced the board with a new board and...
your sensor to the fan is stuck in the closed position. This sensor kicks the fan on when a certain temp is reached in the heat chamber. It opens after cool down and apparently is stuck closed.
Jun 25, 2008 | Heating & Cooling
Carrier Weathermaker SX
If you are running it in the cooling function, your drain maybe backed up. Find your drain outside if you can and suck it with a shop vac.
Nov 25, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Dacor Oven - convection fan stays on while on "bake" setting
Question: does the unit appear to hold the correct temperature? Most convection units only turn the heating elements on and off...not the fan. If the unit is reporting operating temp and then taking other direction...and it is cooking right...you're done.
Nov 14, 2007 | Dacor ECS127 Epicure Stainless Steel...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
108 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
