Question about Cuisinart CSC-650 6.5-Quart
Pot lid sealed shut
Boiled eggs in cuisinart pot but can not remove the lid
0 characters
1 Points
Where can I buy or order the seal for the lid?
Go to Goodwill or thrift store and buy a cheap lid and replace your seal with the one from that lid.
Dec 18, 2015 | Crock Pots & Slow Cookers
How do I remove a lid from a pot after it has been sealed by steam
What has likely happened is when the cooker heated up, the air expanded and escaped, when it cooled off, an air tight seal developed and the top acted as a valve and now the pressure is lower inside the cooker than outside. You need to break the vacuum... This may be done by gently prying the top a bit (carefully so as not to break it) or reheat the cooker. Is there liquid still inside? You could either turn it back on or possibly heat the entire cooker.
Dec 30, 2014 | Crock Pots & Slow Cookers
Should the lid have a steamer hole in it?
Slow cooking is done at below boiling point, so the lid doesn't require a steam hole. That is why you need to boil such things as beans before putting them into the slow cooker, as otherwise they never reach that temperature and can give you belly ache.
Nov 06, 2014 | Crock Pots & Slow Cookers
Original recipe makes 1 cake
  • 2 cups white sugar
  • 1 3/4 cups all-purpose flour
  • 3/4 cup unsweetened cocoa powder
  • 1 1/2 teaspoons baking soda
  • 1 1/2 teaspoons baking powder
  • 1 teaspoon salt
  • 2 eggs
  • 1 cup milk
  • 1/2 cup vegetable oil
  • 2 teaspoons vanilla extract
  • 1 cup boiling water
  • PREP20 mins
  • COOK3 hrs
  • READY IN3 hrs 50 mins
  1. Spray crock of a large slow cooker with cooking spray.
  2. In a medium bowl, whisk the sugar, flour, cocoa, baking soda, baking powder and salt. In a separate small bowl, whisk together the eggs, milk, oil and vanilla until well combined. Whisk in the boiling water. Pour the wet ingredients into the dry and mix well.
  3. Pour the cake batter into the prepared slow cooker.
  4. Set slow cooker to "Low". Cook until cake has no wet spots on top and has pulled away from the sides of the crock, about 3 hours. Turn off slow cooker and allow cake to rest for 30 minutes before serving.
Sep 08, 2014 | Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    I have this crockpot and I just used it three times and all three times dinner burned. I put it on low to cook all day and it cooks on high. I put it on warm and it still boils. I just shut it off to cool...
    Add more liquid. If it is still getting too hot, check to see if it has a temperature knob on it somewhere, if not, you can release some of the heat by removing the lid slightly to let steam and heat release from it as it cooks
    Oct 19, 2012 | Rival 38601 Smart Pot 6-Quart
    The rubber seal on the inside of the lid always becomes loose and doesn't allow the cooker to come up to pressure. I always check it and make sure that it seems to be fitted properly, and when I actually...
    Replacement parts for the Wolfgang Puck pressure cookers are available here:
    If you do not see the part you require or are unsure about the model numbers; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
    Sorry someone has not responded sooner.
    Oct 31, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
    Do you know where I can buy the replacement pot sc-65cp?
    Believe or not, go to your local Goodwill Store! They have tons of crocks and the lids and the cookers separate frm each other that have been donated becase one of the pieces was broken and they donated the rest of the pieces. Lids and crocks typically range from $1.99 to $5.99 and you benefit your community at the same time.
    Sep 05, 2010 | Cuisinart SC-65CP Slow Cooker
    I need a rack for the West Bend egg cooker that the eggs sit in while they are being hard boiled. Mine split in half. Is it possible to buy just this replacement item?
    Focus Electrics is the parent company for West Bend.
    Here is a link to their replacement parts page for egg cookers. Match the model number to your model and then you can find the replacement part that you need.
    Here is the link ->
    If you can't find the correct product or if it is for a different product the page is easily navigatable for changing the product you are looking for.
    If the product isn't available for you has inexpensive Egg Cookers from West Bend for auction.
    Here is a link to a search for West Bend Egg Cookers
    Feedback is appreciated!
    Dec 30, 2009 | West Bend 84323 Slow Cooker
    Burned pot
    a ceramic or clay pot is the only solution.steel is hopeless for casseroles
    same as frying eggs in a steel frypan without the teflon coating
    only true stainless steel is advisable
    May 15, 2008 | Rival 38501 Smart Pot 5-Quart
    Cuisinart CSC-650 6.5-Quart Logo
    186 people viewed this question
    Top Cuisinart Crock Pots & Slow Cookers Experts
    Andrew Taylor
    Andrew Taylor
    Are you a Cuisinart Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
