Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore he3 problem
When i wash my cloths it washes them  for about 4 minites and the the code f 11 and just stops washing thanks
  • we3roses Nov 25, 2007
    We have been experiencing the same problem with our Kenmore Elite HE 3. It will wash for a very few minutes and start the high beeping sound. It displays the error code HF. We have never been across troubleshooting that told us how to do our own diagnostics check, so this was very helpful. We, of course, failed the diagnostics and HF failure code showed back up.
    Our model # is 110.42822201 and we would really appreciate any help with the research on the part number!
    Thank you!
  • Anonymous Dec 11, 2007
    same problem. runs for a few minutes then beeps. HF code appears.
  • 5,911 Answers
F11 is a Communications error.  This problem commonly occurs when the Central Control Unit (CCU) cannot establish communications with the rest of the electronic subassemblies in the washer.  The usual suspect is a loose connection between the door latch assembly or the operator console.  However, if communications were not established with the door latch assembly an additional error code of "Fdl" would be displayed.  You can check the connections yourself by removing the three screws that hold the top of the washer on.  They are located across the top rear of the washer.  Once removed the top of the washer should slide back, then lift off.  The CCU is located in the center-rear of the washer and has a multitude of wire connectors going to it (you can't miss it).  Unplug the washer and and individually begin the diligent task of checking EACH wire connector ONE AT A TIME.  Sometimes all you have is a loose or dirty connection somewhere.  Once you have verified the wiring perform the following:
1. Plug the unit back in.
2. At the operator console select DRAIN SPIN, NO SPIN and under OPTIONS press any key (must be the same key) 4 times.  This will place the washer into diagnostics mode. "C00" should be displayed and the washer will run through a series of tests.
3. If diagnostics pass, the washer will advance to "C05" and eventually drain and spin.  The unit will stop and the clean light will be lit. This may take 15 minutes or so.
4. If the unit fails diagnostics the washer will stop and the error code will be displayed.
Now, if the unit fails the CCU is the likely suspect and will have to be replaced.  If you are savvy enough, you can replace it yourself.  I strongly suggest either writing down the connector locations, take a digital camera and take a picture of it, or do a one-for-one connector swap from the old CCU to the new one.  This method is a little more tedious.  If you find that you have a CCU failure, post back with your exact model number (located along the door opening) and I can research a part number for you.  The cost is generally about $150 (Still cheaper than buying a new washer).
If diagnostics pass with no problems, then you know you were able to locate the source of your problem.
Good luck to you and I hope this helps.
Posted on Oct 27, 2007
The CCU is a known fault. Look around. Google search it. Check out epinions.com. This unit is a major headache. You will replace the CCU every few years at a cost of over $200 each time if you do it yourself.
Posted on Dec 06, 2007
Why does Kenmore HE3 washing machine was clothes in hot water even when I select cold wash?
The initial hot water fill is intended to dissolve powdered detergent. Your Kenmore is not smart enough to know when liquid detergent is being used.
Jun 15, 2017 | Kenmore Washing Machines
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore he3 washer is about 10 years old and the first generation. It is leaving oily stains on the clothes, how can I fix this?
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washing Machine HE3, stop in the middle of the wash
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 seems to use way more than 10.5 gallons
well the water is meter by the unit ,,but i can give you the read outs,,large loads 12 - 14 gallons..medium loads 10 -11 1/2 gallons small loads 9..these are tech estim...it depend on clothing being wash,,,good luck onthejob
Jan 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 stops in middle of cycle, flashes F-11.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
990 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
