Haier HSW02 Compact Refrigerator Logo
A
Anonymous Posted on Feb 05, 2014
Why does my fridge freeze up - Haier HSW02 Compact Refrigerator
2answers
I have a Sharp Fridge-Freezer, model SJ-F78SP-BK. The Fridge compartment freezes. If left on overnight, everything will freeze as if it had been left in the freezer. Freezer is working fine.
please increase the temperature in the fridge portion of your fridge as it sounds like you've set that compartments temperature too low.
Thank you.
My beko fridge freezers fridge keeps freezing
Your t'stat is probably bad. Should be easy to fix. At least it is freezing and not ruining your food from being too warm.
Vent freezing up in fridge side
Isn't it fanned? The fan should blow cold air into the fridge. May be seized or iced up. Defrost, check and clean condenser, run to check.
2answers
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
3helpful
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Hotpoint larder fridge RL150G keeps freezing at the back fitted n
flap controling tempature not closing to controle tempature 9inside ref
2helpful
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
2helpful
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
