Question about Casio ClassPad 300 Calculator
Convert from basic numeral to scientific notation
SOURCE:
  • 8081 Answers
SOURCE: how to turn off scientific notation?
Press [SHIFT][MODE][6:Fix] (number between 0 an 9) to select the number of decimal digits you want. Then press [=].
Hope it helps.
Posted on Oct 09, 2009
  • 8081 Answers
SOURCE: HOW DO I CHANGE MY MODE TO REGULAR MATH EQUATIONS
Press [SHIFT][MODE][6:Fix] and press a numbetr between (0--9). The number you select will be the number of decimal places your results have.
However if a result is smaller than 0.001 it will be in scientific notation.
Hope it helps.
Posted on Oct 10, 2009
  • 8081 Answers
SOURCE: scientific notation
You have a key marked [x10^X] located on the bottom row of keys.
Example: To enter 6.02x10^(23)
6.02[x10^X] 23 [=]
If you have a negative exponent, use the change sign key [(-)]
Posted on May 24, 2010
  • 146 Answers
SOURCE: After working a simple problem adding numbers in
For converting answer in to scientific notation do the following steps.
1.click shift key after that press mode key next to on button.
2.From the menu that is displayed in the screen press 7 for displaying answer in scientific notation.
Thank you.
Posted on Jun 10, 2010
Testimonial: "Very quick and helpful response. Thanks much"
  • 8081 Answers
SOURCE: Trying to get calculator to display in scientific notation
Press the [SHIFT][MODE] to access the (SETUP) screen. -See the screen capture below. Press [7:Sci] to select the output display format to be Scientific.
You will then be prompted to key in a number between 0 and 9 to choose the number of decimal digits.
If you do not want fractions nor radicals set the default Input/Output format to LineIO.
To do so press [SHIFT][MODE][2:LineIO]. After that perform the steps given above to select Scientific format for the output.
Posted on Jul 18, 2010
What does the E code mean
Does the E code look like 10.8372487489E12?
If so, the calculator is either set to scientific notation mode OR the result was an answer that was too big to display on the calculator, so it converted it to scientific notation. To convert from scientific notation back to regular notation, move the decimal to the right by the number of times after the E. In this case, the number after the E is 12, so we have to move the decimal to the right 12 times. In this case, I get the final answer as 10 837 248 748 900.
Good luck.
Any questions, let me know.
Paul
Jan 11, 2016 | Office Equipment & Supplies
WHAT IS THE E CODE
Good luck.
Paul
Jan 27, 2014 | Casio DR-250HD Calculator
I have a Casio fx-300ES Plus, and I want to convert numbers from scientific notation to decimal notation -and vice-versa- for any given answer. In other words, I don't want to redo the settings via...
Sorry to disappoint you but this calculator does not do windows. The operation you require is truly basic so as to be done by hand. It will be simpler for you if you tried to understand the scientific notation.
Sep 21, 2013 | Casio Office Equipment & Supplies
How do i convert a number in scientific notation using the calculator?
You can always enter a number in scientific notation. Use the EE or the [x10^X] key to enter the exponent of 10. Whether it will remain in that form depends on the display mode you set the calculator into:SCI, ENG, NORM1, NORM2, FIX.
However if a result is too big or too small, it will always be represented in SCIentific format.
Sep 09, 2011 | Casio FX-300MS Calculator
Convert to scientific notation 45,700
45 700 = 45700.00..... Notice the decimal mark inserted after the second 0.
In scientific notation you must have ONE digit before the decimal mark: 4.7500 (it is not finished).
By moving the decimal mark from its original place after the second zero to its new place after the 4, you have divided the number by 10000 (one zero for each position change). To recover the original number you must multiply 4.57 by 10000. This is compacted as *10^4.
Thus 45700=4.57*10^4 or as the calculator displays it 4.57E04
If you are entering a number in scientific notation do not use *10^04, but press the [SHIFT][,] for a TI83Plus, followed by the exponent.
Jul 12, 2011 | Office Equipment & Supplies
I have a TI30XA calculator and want to know how to multiply numbers using scientific notation. I have learned how to enter a number (e.g., 1.5 x 10 -6), but when I try to multiply it by something (e.g.,...
Press 2nd [SCI] to switch the calculator to display all results in scientific notation. The results are the same whether you do it in scientific notation or not, it's just how the number is displayed.
Feb 13, 2011 | Texas Instruments TI-30XA Calculator
After working a simple problem adding numbers in scientific notation, I want to convert the answer, a decimal, to scientific notation
Thank you.
Jun 10, 2010 | Casio FX-115ES Scientific Calculator
How to convert a normal ANSWER to scientific
It's been a while since my TI calculator died, but I think you can just hit EE (may be "exp" on your model) followed by =.
Aug 28, 2009 | Texas Instruments TI-30XA Calculator
Calculate {H3O+} for PH of 8.25
It looks like you got the same answer. It's just that yours is in fixed decimal notation, while the one they gave is in scientific notation. Press [2ND] [SCI] to switch to scientific notation.
Mar 22, 2009 | Texas Instruments TI-30XA Calculator
Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
Jan 09, 2009 | Texas Instruments TI-30XA Calculator
Casio ClassPad 300 Calculator Logo
125 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
