I downloaded files from recorder to computer (Windows 7). I want to convert a DSS file to a WAV file. It gives me an error message that an error occurred during the execution of the command. The "Detail" column says "Due to the missing file, reading/writing, access authorization cannot be.... Then it won't let me read the rest of the message. Other files that have been downloaded from other recorders can be converted to a WAV file. Now after downloading files from two separate recorders lately I get this message.
SOURCE: converting wma files to wav files on olympus DDS player version 7
When using the DSS Player v7 software the program is unable to convert WMA to WAV. The option you see there only works when it is a .dss file that needs to be converted to .wav. In order to convert WMA to WAV you will need to locate a third party software program that does this type of conversion.
Go to google and search on WMA to WAV conversion editors.
SOURCE: Olympus DW 90 VN series. I have been using the
get switch audio converter software from www.nch.com.au
works for us like a charm
SOURCE: Software Easywma converter on mac suddenly won't
You must first make sure that the files are indeed good. Install VLC (which doesn't needs external codecs)
http://www.videolan.org/vlc/download-macosx.html
and try to play the wma files with it. If it fails then the files are corrupted. If it works then either the codec pack has been removed - reinstall it from
http://www.microsoft.com/downloads/en/details.aspx?FamilyId=915D874D-D747-4180-A400-5F06B1B5E559&displaylang=en
or the files were coded in a format Easywma can't support - like the lossless and voice one, or with DRM. If it's the last case then configure the recorders accordingly.
