Kenmore Elite 30 In. Electric Self-clean Single Wall Oven Convection Stainless Logo
A
Anonymous Posted on Feb 05, 2014
Probe temp display remains on all the time
Unit is a few months old and has worked great. We had guests Sunday and now the probe temp display remains on. I shut the power and turned it back on the display was off until I reset the clock
2answers
Temp probe indicator stays on
sounds like your probe connection may be shorted. Can you inspect the probe itself, and perhaps do a test for continuity with an ohm meter? Also, you might be able to disable the probe in the menu settings, and run it on manual, just for a test.
Do you still have the user's manual for this unit?
2helpful
Oven does not reach set temp
What are using to measure temp ? Are you using a grocery store bi-metal or professional thermal probe ? and further to that, how long are you waiting to check temp. after range "beeps" or announces preheat complete ? The bi-metal type thermometers do take several minutes longer to reach actual temp as opposed to the ranges temp. probe. Does this unit have the "hidden" bake element ? That sounds like a huge temp difference. These units do require an additional 10mins of wait time after announcing ("BEEP") the preheat is complete (check your manual, it should confirm this) Elements don't go "bad" it either comes on (amp draw) or it doesn't.
hope this helps.
good luck
1helpful
3answers
Kitchenaid KEMS308 display is saying "enter probe temp or remove probe" No probe is plugged in or has been used in a while. This message came up after cooking for about 3 1/2 hours at 300 degrees. Now...
Apparently this is to do with moisture having affected the oven adversely (I got this error message after baking 50 potatoes with all the steam that generated. Have a look at this page http://www.howtomendit.com/answers.php?id=162257 ....the solution is to set the probe for 160F then turn the oven on for 15 minutes or so at 450F. This apparently should dry out the probe position and all work again.....I am trying it now.....
2helpful
GE CONVECTION OVEN. WE GET DISPLAY MESSAGE F2
Diagnosis= failed thermister (temp probe inside the oven cavity) The part number is WB23X5340 and it lists for ~$72.00 at your local appliance parts place.
Bad news is that you have to pull the oven out of the wall to do this repair.
Good news is that it's not difficult to do.
TURN THE POWER OFF AT THE BREAKER BEFORE YOU PROCEED!
Otherwise you'd look like this...
Ready? OK!
All you need is;
1.) Phillips screwdriver
2.) 1/4" socket/nutdriver
3.) Ratchet if you don't have a nut driver
4.) 36 quart Igloo ice cooler (like what you'd take to the lake or the beach)
5.) Sturdy wire (smaller than a coat hanger, preferably)
6.) Flashlight
Did I mention TURN THE POWER OFF AT THE BREAKER BOX?
Now we're ready for surgery.
Open the oven door and look where the oven meets the wood. You'll see a couple of screws there... remove them. Now the oven is ready to pull.
Place your Igloo cooler under the oven. Slowly pull the oven from the cavity until you have it out and sitting on the cooler. (don't sweat it... the oven is light. maybe 75 pounds or so.)
Now that you have it out, open the oven door and remove the oven racks. Look inside (may need a flashlight) and locate the temp probe, there are 2 screws holding it in place. Remove those 2 screws and set them inside the oven cavity, you'll need them soon.
Now go to the back of the oven (slide it if necessary) and remove the back panel. (*Here's a tip... some of these GE units? All you have to do is remove one screw to access the temp probe, so look carefully... don't go nuts here. Sometimes the whole panel/panels DON'T have to come off)
You'll see the temp probe wires... they are 2 small white thermally insulated wires coming from the cavity to the wire harness in the back. Disconnect this harness and pull the old probe out from the front of the oven cavity.
OK... now to get the new probe installed... See that plastic thing on the end of the new probe? It's a pain to get through the cavity where you'll be plugging it into. It's best to have help. but it can be done alone (I've never had help, it's just harder)
Take the sturdy wire (from the tools list) and make a small hook at the end of it. Poke it through the hole that the old probe was stuck through. Now hook your new probe into the hook. Now go to the rear of the oven and gently (did I say gently?) pull it through to the back of the oven.
Now that you have it through, connect it to the harness. Now all you have to do is reinstall the rear panel/s and the oven. No biggy. Just take care not to scratch your wood trim... line it up before lifting and installing.
All in all about an hour's worth of work. I know it sounds like alot more but I could have done this in less time than it took me to type it.
Congrat's on your first major oven fix! Let us know how it turned out.
4helpful
GE JKP26G Electric Oven Doesn't Maintain Temperature
TURN THE POWER OFF AT THE BREAKER BEFORE YOU PROCEED! Otherwise you'd look like this...
Ready? OK!
All you need is;
6.) Flashlight
KEMS377 Lower electric Convection Oven - no probe, won't work!
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
2answers
F3 Fault
Either your new temp probe failed or there is a wiring problem between the probe and the electronic relay control.
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
