Question about Archos 604 Digital Media Player
Archos 604 screen replacement
There are instructions to get the cover plate off of the 504.
The 604 cover plate does not behave like the 504.  Its not hinged on the button side (doesn't appear to be).
How do you get that screen cover border plate off on the button side?
  • 5 more comments
  • c15guy Oct 26, 2007
    The purpose is to replace the display as I already have a replacement for a cracked screen.
    Real quick, here's how you do it:
    Look at the 504 screen replacement instructions here:http://www.newmp3technology.com/504scree...
    This will tell you about the two connectors that you deal with.
    To remove the screen:
    1) Take off the battery.  There are 2 screws under the sticky label in
    the battery compartment.  However you want to do it, remove the two
    black screws.
    2) Remove the button that is at the top one in the buttons on the right
    edge of the 604.  Do this by removing the phillips screw on the top
    edge of the 604.  This is not a button per se, but rather a label
    button (it cannot be pressed and serves no function).  This will expose
    one of the tabs holding the faceplate down and makes reassembly MUCH
    easier.
    3) Remove the top two phillips screws on the edge away from the buttons.
    4) Now the faceplate is unattached and you can gently use a flatblade
    screw driver to lever it away from the body.  Start at the edge away
    from the buttons.  Be gentle.  You will have to pop the screen out of
    the faceplate as you lift it away.
    5) Follow the 504 instructions for the two connectors for the screen.
    PAY CLOSE ATTENTION TO NOT PUTTING STRESS ON THE RIBBON CABLES FROM THE
    SCREEN!  This is actually the easiest way to damage the display
    operation.  Pulling on those ribbon cables.  Second easiest way to
    damage is to break the screen.  Don push on the screen itself.  Press
    on the edges.
    6) Reassemble.  The hardest part and the one where damage can be done is getting the stupid display to reseat in the faceplate.
    All through, verify the screen is working periodically by putting the battery in and turning on the player.
    As with any electronics, insure your hands are static free.
    Good luck.
    If done smoothly, this whole operation can be done in about 10 min.  (thats if the screen will seat itself in the faceplate)
  • c15guy Jan 05, 2008
    I forgot one more thing. Important. You have to use mylar tape to insulate the ribbon cable. Look at how the original ribbon tape was insulated. Mimic'ing that exactly is your best bet. I don't recommend your average person replacing his own screen. Its worth the labor difference with Archos (assuming the act in the time frame they say they will) to not have to stress over it.
  • c15guy Jun 30, 2014
    As I recall, there is one more detail here: The display ribbon cable has chip capacitors and other supporting electronics on it. This side of the ribbon cable should have an insulator (mylar tape) applied and covering any of these exposed circuits. Remove the mylar tape from the old cable and apply it to the new cable if there is no insulation covering these cable components. If you do not do this... everything can work until you fully push the display back onto the case - at which point you are likely to short a chip capacitor to something else. This won't kill the new display, but the display won't work. Unpop the display again and it's working. It took me a few tries to go ... DUH ... and look for that mylar insulator (just reuse the old piece of mylar). Its dumb that the new displays (when I did this) didn't come with it.
    f u fixya... I typed all of this and then you threw it away making me log in. grrr
    Here it is again (and I'm not going to fix your website so it doesn't do this stupidity)..
    I forgot one important thing here: if you look at the display ribbon cable, you'll see some intrinsic circuitry: chip capacitors and stuff. These are exposed connections, i.e. not insulated. So you must insulate them before pushing the display back onto the unit. The manufacturer used mylar tape to do this. The easiest solution if you don't already have this is to remove the mylar tape from the old cable and reapply it to the new. Of course, cover completely any ribbon cable components. That's all you are doing. Then when you push the display down, you won't short any of these chip capacitors to other metal and cause your display to blank out (it likely won't damage the display electronics... but you'll be going wtf as your display blanks when you push down to snap it into place and it starts working again when you move it away from the unit. It took me a couple of times to go ... DUH as I released there was no insulating coating over those components and what was happening. You had to have seen me... so focused on not breaking the display or cable connectors and figuring out why that darn screen worked not snapped in place but stopping working once snapped in.
I have archos 504 160 gb when it turn on i have message (recovery code 4) would you like to recover your system ? no - repair disk - format disk when i push no no thing action . when push repair or...
This is a recovery mode, and this menu allows you to:
-Format your hard drive
-Restore your system
In case of repair disk is selected :
For the first step you have to go on our website, and download the latest firmware update for your product.
Plug your Archos 504/604 on the computer and copy the firmware previously downloaded at the root of your device.
Disconnect your device as usual, and select done on the screen.
You have to plug the dc adaptor to update successfully, press a button to reboot your device.here is the web address  http://www.archos.com/support/support_tech/updates.html?country=us&lang=en&#firm
Nov 27, 2010 | Archos 504 500870 Digital Media Player
Archos 504
Go to this website and download your FREE manual in pdf form. (Opens with Adobe Reader)
Please do not forget to rate me.
http://safemanuals.com/user-guide-instructions-owner-manual/ARCHOS/504-_E
May 19, 2010 | Archos 504 500870 Digital Media Player
Archos 504 hard drive upgrade
  • go to archos.com
  • go to support and account near top of your screen and go to downloads
  • the archos website should tell you what to do next
Oct 06, 2009 | Archos 504 500870 Digital Media Player
On line manual for Archos 504/604
In this case just Click on the Link: http://www.scribd.com/doc/2458534/english-user-manual-archos-504604-v2-2-converted
And you can Download the Manual from there in Adobe or Microsoft Word Format...... Thanku
Jan 28, 2009 | Archos 604 Digital Media Player
Archos Recovery (code 2)
Send them back to Archos if they are still under warranty. If not, you're out of luck because they'll charge you about US$140 to repair the hard drive + postage.
Sep 10, 2008 | Archos 604 WiFi Digital Media Player
Archos 504 RESET button
Please open Battery cover and PRess Small Golden button just near the HDD , it will restart the Devie
Jul 21, 2008 | Archos 504 500870 Digital Media Player
Archos 604, frustrating problem.
Ribbon on hard drive came loose, take out battery. remove 2 screws on inside of battery compartment (not the ones mounting the plastic frame) remove 2 screws on side of unit(not all four, tough to get back together if you do. take ribbon and reset it into hard drive first, then unit. slide battery back on and backcover, turn on, problem sould be sovled. If not, try again the ribbon is not seated. it took me 3 or 4 times, about half an hour, with jewlers phillips-head screwdriver. my Archoes was a 604 wi-fi but it shoud work pretty much the same on 404, 504, 604, 605, 705 605 wi-fi, and 705 wi-fi.
Mar 24, 2008 | Archos 604 Digital Media Player
Replacement screen
$150 fix by the Archos people. You can get a replacement screen for $100, but the repair requires special screw drivers, and a low heat soldering iron and some skill.
Dec 11, 2007 | Archos 604 Digital Media Player
Recovery (code 2)
I got the same message when I took out the hard drive. I'm sure this will void any warrant, but maybe you should open it up and make sure the hard drive ribbon is secure.
Nov 12, 2007 | Archos 604 Digital Media Player
Archos 604 Digital Media Player Logo
856 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
