Question about Panasonic Diga DMR-EH75V DVD Recorder/VCR/HDD
Hard Drive to DVD-R recording
Using a DVD-R, the unit will not record from the hard drive in high-speed or normal speed.
  • barbiegeek Mar 09, 2008
    Mine won't record from HDD to DVD-R, nor will it play commercial DVDs (eg, rented or purchased DVDs). I'm hoping that some lens cleaner will do the trick, but other solutions would be welcomed.
Can I record what is on the Tv to my panasonic diga through some kind of hookup?
Posted on Aug 17, 2008
How do I transfer recorded movies to a external hard drive?
That depends. What device did you use to record these movies? If you recorded a movie using a DVD recorder, connect your external hard drive to a PC device which has a DVD rom. Go into the files, copy and past the file to your external drive.
Sep 15, 2016 | Hard Computers & Internet
Why does my LG LH-RH7500P hard disc recorder keep indicating "please wait"?
If it does it and returns to normal operation, then there's probably nothing wrong with it. Unless you have nearly filled up the hard drive with TV recordings. It might struggle to get going if that is the case.
However if it doesn't come out of it, that's a fault on the unit. It could be a faulty hard drive, or something wrong with the computer circuits of the machine.
Mar 22, 2015 | Televison & Video
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
May 11, 2014 | Televison & Video
My dmr-eh55s will no longer transfer from the hard drive to the DVD in the high speed mode. It will in low speed mode (real time).
It sounds like the DVD-RAM drive is about dead. Panasonic did not make them to be very durable.
Panasonic sells replacements at a high cost.
Replacement drives may work from used models including:
Jun 17, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Can't Record, wont read blank DVD
Have the same problem with this piece of junk.
Tried all the solutions. Clean lens etc. Nothing helped.
Tried replacing the drive with another that I had. No go, apparently has some proprietary firmware.
I was about to throw it in the trash when I suddenly realized that it had a TV tuner. Hooked it up to my computer through a Pinnacle Dazzle interface and VOILA I had a hard drive recorder. I either just watch it on my monitor or burn a DVD if it is something I want to keep. Hey that is better than pitching something you paid $300 bucks for in the trash. You can pick up a dazzle or similar on EBAY for a lot less than a new Hard disc recorder will cost you.
Jan 23, 2009 | RCA DRC8005N DVD Recorder
Will not dub to dvd-r from HDD in high speed mode
It will only high speed dub in the speed it was recorded in. You can dub, for example, SP on your hard drive to SP on a DVD. You cannot dub high speed, for example, SP on your hard drive to LP on a DVD.
Dec 01, 2008 | Panasonic DMR-EH50 DVD Recorder
Sony rdr-hxd870 - how to record onto hard drive?
JUst press Record either on the remote control or on the main unit!
Seriously, how retarded can you get!!
Jul 22, 2008 | Televison & Video
Hard reset
If you put a disk in and all it does is click several times, it's more than likely the spindle motor. It's best just to replace the DVD drive. Recording in the default high speed mode tends to cause the spindle motor to fail over time. Usually in a very short period of time. It's best to set your record speed to the standard mode to avoid premature failure of the spindle motor.
Mar 14, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Panasonic Diga DMR-EH75V DVD Recorder/VCR/HDD Logo
182 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
