Question about Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop
Fan won't shut off
The fan continues to run.  The knob has not effect on it in any position.
  • frostel Nov 29, 2008
    I have the same problem but the cooktop is built in to the counter with cupboards beneath, how do I access the switch to remove it?
  • jkusano Dec 22, 2008
    How do you access the fan control switch?
  • 473 Answers
You have a bad fan control switch.  Part # is 74009255 and you can get it at http://www3.sears.com/.  Cost is $55.99.
Posted on Oct 26, 2007
Have a gas cooktop that clicks even when the knobs in are in the off position
Good Afternoon Hon,
I understand that your Frigidaire gas cooktop, model# FGC30S4ASA, is clicking even when the knobs are in the off position. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and listen for the clicking with the burner knobs in the off position. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Cooktops
Vet fan will not shut off
Have a look for the master switch on the wall some were that should work
Mar 15, 2014 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
Middle section ticking sound with sparking as if trying to ignite even though knobs
Try using a pair of pliers and pushing down as you turn first counter clockwise as if you are turning the gas on then back clockwise till it won't turn anymore. If it's still trying to ignite see if its the oven or make sure that its the burner that's trying to ignite . I''m not a appliance person just a home maker so if it were me and none of those things work turn off the gas to the stove unplug the power to the stove and call the gas company or appliance center. One thing though some of those type of knobs are two parts like they have to be pressed down to turn on the gas. Or the have to be set in a certain position to engage the ignite switch. If you know a little about wiring look at the switch and check the wires. But make sure before you do anything that there is no gas on.!!!
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
My ge monogram stove top burner( model zgu366h)continues to ignite. even after the flame is lit
If you are saying the clicking continues you must move the burner knob past the LITE position.
If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Nov 30, 2010 | GE Cooktops
The igniter on our cooktop is clicking
Sounds like one of the burners electronic switches is bad. Under or behind the knob that you turn the burner on with is a switch. One or more of those switches is bad.
Sep 13, 2009 | Cooktops
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 | Cooktops
Ignition will not stop clicking...
Did you clean your stove recently? If the switches under the burner knobs get wet they will cause the burners to click. Unplug the unit or shut off the power for a day. Once the swithes dry, it should work normal.
May 05, 2009 | GE 30 in. Profile JGP932 Gas Cooktop
Electronic ignition
Most likely you got water (or some other liquid) into the control knobs. Unplug, go to bed and try it again in the morning. If you continue to futz with it, you run the chance of burning out the electronics in the control knob, like I did. :(
Oct 22, 2007 | Miele 35 in. KM326G Gas Cooktop
Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop Logo
297 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
