Question about Orion HCCA-D5000 Car Audio Amplifier
Orian d5000 amplifier
Amplifier was working fine at medium power then suddenly dropped out. The Led Lights and I hear it switching on inside but get no output to Subs.
  • Twanrawlins Oct 08, 2008
    my amp doesnt go into protect mode but i hear a clicking sound and i get nooutput from my amp
  • 15,935 Answers
Output module probably gone, or switching relay stuck. Refer your problem to a certified tech to avoid injury.
Posted on Dec 22, 2008
Hi, my sony ta-fe370 has stopped working. All fuses seem fine and there is no obvious visual problems inside. The red led next to the power button comes on but then goes out again. The source selection...
What power are you meaning that Also, all of the other decks connected to this also have lost power Is this mains power If so check the power on the switch
Oct 12, 2013 | Sony TA-FE370 2-Channel Amplifier
I have a orion hcca d5000 and keeps going into protection. there is nothing hooked up except power, ground and remote. I hook amp to a bit writer and it reads over current. Can this be reset, or is my amp...
yes mines does the same and everyone keeps saying check the ground upgrade to the big three and so on personally i think this series and there new amps are just junk. Mines been in protect since i got it two years ago, once inawhile would turn off with big bass drop and now the amp doesnt really work in master switch but works on the slave i just think the amp was built poorly so, my advice get it bench tested before you do any new upgrades
Sep 02, 2010 | Orion HCCA-D5000 Car Audio Amplifier
Playing it loud for about 20 minutes it suddenly fell silent. Power is fine as is fuse. What has blown?
Hi, even though the mains fuse on back of amplifier is fine, the speaker fuses might have blown.
Now really you need to take it to get repaired but if you know someone who has electronics knowledge they could look inside the amplifier to check the speaker output fuses.
I wouldn't want to advise you to do it as there are dangerouse voltages inside the amplifier.
If you need more help, I will guide you.
Regards - Anthony
Jan 30, 2010 | Sony TA-FE370 2-Channel Amplifier
I have a 2000 watt hifonics brutus amp ...it worked fine but 1 day it just stopped working..the power light doest light up but the hifonics led lights are still on...whats the problem?
there is a step up converter inside the amp that likes to come loose from the board. This may be your problem. Otherwise Check all the chips for burns or disconnect
Nov 13, 2009 | Hifonics Brutus BX 2005D Car Audio...
Amplifier Powers on But Does Nothing!
Try finding a better ground some amps are more finicky about ground than others. Try running a wire from the ground on your battery to the ground on the amp if this works then you will know you need to find a better place to pick up a ground.
Jan 24, 2009 | Pyle BZDBP212 Car Subwoofer
Amplifier does not work
remove the speaker wires and re-test. If the amplifier powers on, without fault, you know the sub(s) and/or wiring are the culprit. If the power and ground are ok, take the amplifier in for service. The indicators are there to let you know of a problem. If it is an internal one, a certified tech will be required.
Dec 17, 2008 | Orion HCCA-D5000 Car Audio Amplifier
500.1 amp power lights blinks on and off
Protection mode; follow this link to get a manual for the amplifier: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Below information is from the manual:
Status Indicator Lights / Protection Circuitry
There are three status indicator lights on the top of the amplifier. These are as follows:1) "Power" (Green): lights to indicate that the amplifier is turned on and operating normally.
2) "Thermal" (Red): lights to indicate that the amplifier has exceeded its safe operating temperature, putting the amplifier into a self-protection mode, which reduces the power output of the amplifier. The red light will shut off and the amplifier will return to normal, full-power operating mode if the heat sink temperature drops back to a safe level.
3) "Low ω" (Amber): lights to indicate that the impedance of the speaker load connected to the amplifier is lower than the optimum impedance load range for the amplifier. When this light is on, a protection circuit engages and reduces the power output of the amplifier. The amber indicator will also light when a short-circuit is detected in the speaker wiring (this can be a short between the positive and negative speaker wires or between either speaker wire and the vehicle chassis).
There is only one condition that will shut down an undamaged 500/1v2 completely… If battery voltage drops below 10 volts, the entire amplifier will shut itself off. The green "Power" indicator on the top of the amplifier will turn off when this occurs. The amplifier will turn back on when voltage climbs back above 10 volts. This may happen in a rapid cycle when bass-heavy program material causes a weak charging system to dip below 10 volts momentarily. If this is happening in your system, have your charging system inspected to make sure it is working properly.
For information on troubleshooting this amplifier, refer to Appendix E (page 21).
Jun 25, 2008 | Jl Audio E1200 Car Audio Amplifier
Orion HCCA-D5000 Car Audio Amplifier Logo
126 people viewed this question
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Marvin
Marvin
Morne Olivier
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
