Pioneer Model XRP330M
We have a PIONEER STEREO XRP330M CD/RADIO/TAPE DECK and require new FLOAT RUBBERS, part reference as follows:
                 PEA1118  x2
                 PEB1144  x2
these will stop the CD skipping apparently the rubbers are warn.
If able to advise us where we are able to get any from would be much appreciated.
Kind regards
Lyn Macdonald
215 Middleswamp Road
RD 26
Temuka
South Island
NEW ZEALAND
shanth
  • 108 Answers
SOURCE: CD player will not play CDs
1.Check whether your cd s are good and readable
2.then the problem with the cd player laser beam reading assembly and its associating blocks
3. i guess your cd player laser beam lens is too weak or dead.
4. There is possible to change the lens system with a new one
5.Contact service centre for further rectification
Posted on Dec 22, 2007
SOURCE: Numark CD MIX2 right deck skipping, sounding scratchy
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
Posted on Sep 27, 2008
SOURCE: pioneer cd tuner deck model xc-is21t missing lead
go to www.donberg.ie and search for ADE7039 CONNECTING LEAD , order code piac 173
Posted on Oct 14, 2008
  • 133 Answers
SOURCE: MY CD PALYER DOES NOT WORK. ''DISC NOT FINALIZED'' IS DISPLAYED.
If your CD player has been working for many hours and cleaning the lens didn't help, then the next thing to do is changing the spindle motor (the one that spins the disc), since the brushes and the commutator get dirty/oxydized with many hours of performance.
The motor can also be cleaned, but it's kinda complicated and delicate to do it, so you might want to change it instead.
The same holds for the slide motor (the motor that changes the position of the laser pickup).
To clean the motor you need to desolder/remove it and open it up (you need to bend out the clamped parts on the motor housing to release the cover - also, mark the position of the cover so you can put it back in place in the same position as it was prior to opening it - some motors have an indentation so that the cover fits in place in only one position).
Then you need to remove the cover (this is a delicate procedure as you can easily damage the brushes).
You can clean the brushes and the commutator using a long pointed scalpel - gently scrub away the brownish/black residues on both the brushes and the commutator.
Now you need to put the motor back together, taking care not to damage the brushes when you put the cover back in place (kinda tricky but it can be done).
After closing it, see if it runs smoothly, you may want to try and run it on some 3 volts - it must run quite silently, with no more than a gentle humming sound.
If it runs ok, you should use a tiny flat screwdriver and a small hammer to bend the housing edge back onto the cover to fix it in place (basically, you need to rehammer back in the clamps that held the cover in place, this is also a bit tricky and delicate thing to do).
Now reinstall/resolder the motor back in place (motors on some brands/models can be worked without removing them).
Well, i've just told you how i repaired quite some CD drives which were virtually dead, i'm actually still using a yamaha which is more than 15 years old (i myself have been using it for at least 10 years now), i got it as a scrap piece, it returned to life after the above described procedure and it actually works perfectly up to date.
Anyway, i guess the easy way is to simply replace the motors (they need to have the same axis dimensions and mount holes as the original ones, also they need to run on the same voltage - things to keep in mind when you are looking for new motors).
Hope you can get it working...
good luck
3rq8 (Triarcuate)
Posted on Jul 24, 2009
SOURCE: Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
I had the same problem but fixed it by replacing the cd belt which was broken and relined the main cd plate which holds cd to correct position . and god fixed it.
No more errors and now a great cd Hi Fi.
Make sure all s aligned and blow out all dust with an blower or air compressor.
I pull the top plates off blow air into them and replaced a broken belt for cd's and not it's new machine.
You want to fix it than fix at the source.
Posted on Jan 08, 2011
I have a pioneer dual tape deck model ctw606dr can i record from a cd player seem like it only records from tape to tapr
If your Pioneer tape deck has a provision for input source selection, it can record from a CD player.
Nov 30, 2017 | Pioneer Audio Players & Recorders
How to reset pin code PIONEER KE-1900 CAR RADIO CASSETTE as I have forgotten it
What pin code? I have never seen a pioneer tape deck that requires a security code.
Jun 20, 2011 | Pioneer KEH-1900 Cassette Player
My daughter has a 98 olds 88 i removed the stock stereo and put in a pioneer cd player but i didnt see any wire on the stereo side for the elec. antenna i was wondering how i can wire it to work
Most aftermarket pioneer cd/radio decks have the electrical connector for the antenna that I've seen.
Is this a cd only deck, or does it have radio functions?
Did you use a new harness wiring adapter to get the pioneer radio to work with the old harness?
There should be a color coded set of wires for the power antenna on that. And, then the Pioneer radio should have wires that were labeled for the power antenna.
Oct 08, 2010 | 1998 Oldsmobile 88
I am needing to hook up a pioneer 6 disc cd changer to a pioneer stereo I have all the harnesses and wires
if hookimg up to a pioneer deck its just more simple by just plugging it in to the back of the stereo. but if u are going through an fm modulater u must adapt antenna to the radio and hooking up ground and ignition to power up box. if needing color configuration please call us at car r us audio at 520-882-8979
Jun 10, 2010 | Pioneer Car Audio & Video
PIONEER CT 670 user manual ,in need,thanx a lott
You can try to download the manual from the following site.
http://www.fulldownloadshare.com/finder/PIONEER+CT+670+tape+deck+manual.html
I am not sure how big it is, but you can at least look at it if you don't want to print it out.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Feb 08, 2010 | Pioneer Audio Players & Recorders
I have a Stereo Double Cassette Deck; Pioneer CT-W404R. I've set the REV MODE switch; I've pressed the record button; I press playback and the tape for recording begins moving, but not the other tape. If I...
I was following instructions for "Recording." On the next page were instructions for "Tape Copying," though the first page began with, "Load a tape for recording in Deck II." That sounded like what I wanted. Anyway, that was my error.
Oct 11, 2008 | Pioneer Audio Players & Recorders
SX-1600 + KD-491F
Appreciate the additional information.
To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
Very Low sound
Make sure none of the tape monitor switches are on as this is a typical symptom when one or more of the tape monitor switches are active.
Sep 27, 2006 | Pioneer IS-22CD CD Shelf System
160 people viewed this question
 Grubhead
Grubhead
