The Sony NWZ-3438F uses only the 'Track #' in the tag to order songs, not file name, not 'Disc #', and not 'Title.' Your file names are likely in the order you want, but the tags are likely not updated with the same information. Use a program (like mp3tag) to modify the tags and assign the 'Track #' in the order that you want it to play. Good luck!
Update: As I've played with my Sony a little more, I've found that it does use more than just 'Track #' to order the songs. As I originally posted, the Sony still gathers it's information from the tag data and not from the filename. So if you want to order your songs, you'll have to use tagging software like mp3tag. It appears that 'Artist' is the first field that it sorts on. 'Track #' is a secondary field.
