Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
Rinnai 1004 fa not lighting
a code witch reads 99 apears and it tells you to check for blocked exhaust, i have the unit off the wall on a bench with no exhaust on it and it does the same thing
any idea?
  • 1,420 Answers
Re: rinnai 1004 fa not lighting
This heater needs some back pressure on the exhaust to work so while it is on your bench, take the reducing coupling found on your vent system and put it on the exhaust pipe to restrict the outlet size. Now cycle the heater with the front cover off and with both of the small rectangle viewing ports off so you can see the flame. The heater fan will start to turn closing the contacts on that little square pressure switch. If it does not close you will get this error code. Make sure the small hoses are attached to the switch and the exhaust system. If you hear some clicking going on at the gas valve you can assume that the pressure switch is closing. The gas valve will energize and send gas to the burner. Look for flame. There is a small probe that will sence flame within a few seconds and keep the unit on. If it doesn't, it will turn the unit off within 3-5 seconds. I suspect that a spider has set up shop somewhere within the heater and either restricting the flow of air to the pressure switch, the burner or you may have a bad pressure switch. If you need a switch, I can send you one for $15. Contact me at "".
Posted on Oct 26, 2007
I spoke with tech support this morning. Some new units are shipped with two tubes disconnected from the exhaust port. Tubes are found in the back on the right side as you face the front of the unit. Black tube should be connected to BK connection, the clear tube to the other.
Posted on Jan 07, 2008
0 characters
3 Points
My Rinnai 1004F giving me error code 99
This fusible link may be open. Try jumpering the two leads and see if the unit operates. If it does replace the fusible link. Do not operate the unit without the fusible link for an extended period. It is a safety device and is there for a reason. Hope this helps.
Jan 04, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My rinnai 1004 keep shuting off and is blinking 14
CODE DISPLAYED FAULT REMEDY 11 Ignition Failure Check that gas is turned ON. Service call if repeated. 12 Flame Failure Check that gas is turned ON. Service call if repeated. 14 Overheat Clean filter. Service call if repeated. [1] 16 Room Overheat Lower room temperature to less than 104°F (40°C). 31 32 Room Temperature Sensor Faulty Service call. 33 34 Overheat Temperature Sensor Faulty Service call. 49 Sensor Breakdown Service call. 53 Sparker Failure Service call. 61 Combustion Fan Failure Service call. 70 Faulty ON/OFF Switch Service call. 71 Faulty Solenoids Service call. 72 Faulty Flame Rod Service call. 73 Communication Error Turn heater OFF, then ON again. 99 Flue Block Check around the flue terminal for blockage. [2] [1] Remove any obstructions. The flue needs to be kept clear to expel exhaust gases. If the appliance fails to operate contact a qualified service agency. [2] If the fusible link needs replacement, it must be done by a qualified service agency. In addition, the cause of the overheat needs to be determined. The fusible link is a one use safety device that breaks to shut off the appliance.
Dec 17, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I bought 2 1004's from different sources. They both said they work fine. When I test using my barbecue tank they both let me put in desired temp, make a little noise like they will come on but then just...
You don't have the air pressure sensor tubes off the air hose hooked up. Without those there will be no gas flow. Hook up all the exhaust pipes as if they were going through the wall and retry.
Sep 27, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Flashing code 99
Error code 99 has to do with the flue pipe being blocked. You could have ice or frost on the exhaust or air intake. This reduces the combustion air to the unit which in turn stops the fuel flow.
Tom Hawkins
Dec 21, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 error code 11
I had this problem and oops, the gas intake was closed. check the door on the right side of the unit, and make sure the valve is turned to "open" .... here's the link for the online manual if you want it:
Oct 04, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 heats to a temp 4 degrees higher than set temp, adjustment?
You can adjust the position of the room air sensor found on the back of the unit between the heater and the wall. It is a black rubber bulb with yellow wires. There is a few inches of extra wire you can extend higher to get a more accurate reading of room air. While you are back there, check for drafts that will give you false readings.
Sep 23, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004 - Temp on thermostat reads 10 deg cooler than actual, keeps running
Behind the unit near the floor level, is a yellow wire with a black bulb at the end. This is the actual sensor for returning air. If there is cool air infiltrating the area where it is located, it will keep the unit running until the return air reaches temperature. You could also have a bad sensor but highly unlikely. Make sure there is no air infiltration influencing the sensor. Also, you can unclip the sensor and pull out a few more inches of wire to locate it higher up away from the floor. Tie it up with a wire tie.
Rinnai it testing a remote thermostat but as of yet, there is no plans to offer one.
Nov 24, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Power reset - Rinnai 1004
the rinnai is like a monitor. just unplug it, wait five min and plug it back in. then radjust your temp set point and it should pick back up. when there is a power outage the led-s flash 88:88
Nov 17, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
452 people viewed this question
Top Rinnai Heaters Experts
Level 1 Expert
Kenneth Wilson
Kenneth Wilson
Level 1 Expert
Are you a Rinnai Heater Expert? Answer questions, earn points and help others
