Question about Samsung Weather Resistant Security Camera SSC-12C
Samsung B/W Observation System - Model# SSC-12
My Samsung system that was purchased in January, 2004 stopped working.  The green power light in front of the monitor blinks off and on making a click sound and the monitor (SSC-12M) screen is black.  I have 3 outside cameras (SSC-12C) hooked up.  I also have it hooked up to a time lapse vcr recorder (SSC-1280).  Is the monitor bad, or is it the cameras?  How do I find out.  I never had a problem before today.
  • 5 more comments
  • Anonymous Mar 16, 2008
    Makes a clicking noise and no picture ----can it be fixed or need replacing ??
    Thanks
  • Anonymous Apr 23, 2008
    Same problem. Power seems to be cycling on the system which powers the cameras and monitor together. There is a faint burnt smell. The fuse looks fine. Will have to rip it apart further to see if it is something I can solder.
  • Anonymous Jul 25, 2008
  • wendell9913 Nov 09, 2008
  • tmilli Dec 14, 2008
    Same problem experienced with my SSC-12 (i.e. will not power up and has clicking sound from the back). Have the unit into a TV repair shop to see if they can breathe some life into it. In the interim have been looking for a replacement unit (basically same size i.e. 12" due to the location where I want to place the monitor). Seems that 12" security systems with RJ-11 camera inputs are hard to find. The only other options I have found are the SMO120S and (LG) LSP-M1012E and I have yet to find a source where I can purchase either of them. If the TV repair shop does fix my monitor I will advise what was done.
  • HERNANDEZHHH Jan 08, 2009
    The monitor flicks on and off. Have disconnected and reconnected and within a minute it starts doing it all over. Have 4 cameras connected to it.
  • Anonymous May 15, 2009
    I too have the same set-up with 3 cameras. Monitor screen is black and when you turn it on, green ligt flashes and makes the same beep, click noise. Purchased in 2004 as well. Cannot find owners manual and cannot even locate any information on this product on Samsung's website.
  • 5 Answers
Same problem here after a close lightning strike. Fuse was good, main switch was operable. Noticed a charred spot next to a heat sink which has two diodes that appeared to be burnt. One being a zener diode, the other a simple diode. Gonna replace them and see what happens. Any suggestions?
Posted on Jul 31, 2008
I have the same problem and I found out that a resistor went bad and then a capicator went bad.you must have them check and replcaced
Posted on Jun 03, 2008
    Brigadier General:
  • 6,966 Answers
The blinking green power light in front of the monitor - indicates 2 possibilities:
1. no video signal received (highly unlikely - 3 cameras); or
2. most likely internal monitor problem with part(s) of its circuitry and the auto-protect/shutdown is activated, hence the powering on and shutting down (blinking green power light). The clicking sound is most probably a relay inside the monitor that switches the power on and off.
A few thoughts:
1. The cameras get their power from the monitor. So if the monitor goes bad, the cameras will also be inoperable. And the same also holds true if any of the camera develops a power problem, the monitor would react;
2. The VCR is a separate unit and gets its video INput from the monitor and would not be an issue at the moment.
Things you can try:
a. Remove all the RJ11E ("Telephone" type) camera inputs and plug them back one by one just to determine if it's a camera problem and the monitor is simply reacting; or
b. Use a different monitor of the same type of input/configuration connectors.
Hope this be of some idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Oct 26, 2007
We have this system at work. It will not play back the vhs tape. I've tried to press 'vcr' button on monitor and a black screen with 'no signal' flashes. Also tried just pressing play on the vcr, still nothing. I have checked connections, disconnected and reconnected. Getting alittle frustrating. Please help with any ideas. Thanks
Posted on Jul 18, 2010
  • FIBER0PTIC HELL (FIBER0PTIC)
    I have the same security car. 8hr v hs tape will 960 hours worth of pictures.
    Pull the recorder off the monitor, put try to play back on another tv
    I will go check my unit now, maybe record a video if needed of my setup and connections.
    New Friend:
    Problem Solver:
  • 6 Answers
I have replaced many since this post in 2o13...I am a Security camera G0D now with many installs and hacks... that said the SSC-12a system with 4 cameras connected to a single SSC-12m Monitor has been working 24/7 since I installed it and still works perfect. no video loss or downgrade since I installed it.
I added infrared lights to the area and picture is crisp and viewable in almost complete darkness.
I did run new wires going to the private rooms, and down the upstairs hallway and rather than spend money on expensive cables I made my own from Cat-5 network cables, 8 wire pull and added 6 wire modular adapter.
You need to reverse the pins on the other side if you decide to make your own cables.
Why they don't all use the same pin settings and allow the use of generic one cable fits all applications is beyond me..aside from the fact a 75' cable ($83.13 when initialed initial system!!!) has a large markup, I will scan/post the amount Samsung billed for the cable and shipping when I pull Manual out, I saved all docs on my installs.
Note: I did run 150' custom cables and crimped them myself. I have no video loss however Samsung said 100' would be the maximun without boosting the signal, again more money more equipment.
Take care, back in 5 years +/-
http://downloadcenter.samsung.com/content/UM/200604/20060413114602671_SSC-12.pdf
FIBER0PTIC/FBR, The HUMBLE Guys, Napalm and Worship Inc..
Posted on Nov 09, 2017
I am looking to replace my camera i only have one working and would like to get 3 more to replace
Posted on Jan 17, 2010
  • Raj Jul 05, 2012
    Are still wanting to change your camera's?
  • Rt
    Rt Oct 28, 2013
    yes I am still wanting to replace my camera's
Complete service manual for Samsung B/W Observation Monitor SSC-12M AC120V, 60 Hz, 38 W. The green front panel power lamp flashes and the machine emits a clicking sound. I have checked connectivity to...
Unfortunately, the devices aren't listed as the "set" - can you reply with the exact model number from the main unit?
If i cannot obtain the schematics after hearing from you... I will contact Customer Service to initiate a refund or switch to another expert.
Thanks!
Sep 28, 2011 | Samsung Weather Resistant Security Camera...
Tip
Samsung SSC-21 Installation Manual Have you lost the Installation...
Have you lost the Installation Instructions for your Samsung SSC-21Color Quad Observation System?
Click here to download a digital, searchable, pdf version of your users manual / installation guide.
I hope that helps.
on Apr 16, 2010 | Home Security
I PURCHUSED a samsung ssc-12 security camera has no manual. what are the tree green conectors for
You can download the manual at
Nov 01, 2010 | Samsung Weather Resistant Security Camera...
We purchased a home with 4 samsung cameras in various places around the exterior. They are all wired back to the master bedroom with what looks to be CAt-5 cable. What do I need to make this system work??...
Hi there, depend on the model of your cameras, normally if there are samsung it should say the model # ( ssc-12c,soc-c120 and so on) What look like CAT-5 are normally RJ-11 very similar to a phone connector. If your cameras are one those mentioned above you will need a monitor that support that type of connection like the ssc12m or ssc-17webm if there are black and white or the SMT-190M if there are color cameras. or a DVR with similar connection type like the SHR-1041.
Thank You,
nationalprosecurity.com
Oct 17, 2010 | Samsung Weather Resistant Security Camera...
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
I have a Samsung B/W Monitor, model Name SSC-12M for an observation System. Turns on for a few secomds, and then gets a straight line across and turns monitor on and off, Capasitor maybe? Worth repair ing...
The vertical Ic either has bad connections or is defective. Look for a small flat IC attached to a heat sink with about 11 pins. Try resoldering the pins first. If that fails to resolve it, replace the IC. This IC may be marked LA7837 or something similar. If you are unsure, post the marking here and I'll confirm you have the correct part.
Dan
Aug 28, 2008 | Samsung Televison & Video
Epson Stylus photo 810/ink jet printer
Hi Alan
I expect by now you've solved this problem - but just in case .....
The waste ink "protection" counter has exceeded its limit and needs resetting. You can do this easily by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (810), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
May 17, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Main menu problem with Samsung SSC-1280
That seems to be SAMSUNG's answer for a lot of their problems. Please to note I have read much too many of their manual. If you didn't catch that - this is the worse written manual I've seen in my 34 yrs. in electronics. My choice is to learn their language, put up with this type of garbage or write this off as a learning experience. I choose to exclude SAMSUNG from my list of considerations for any future equipment purchases.
Mar 16, 2008 | Samsung SSC-960 VHS VCR
Ssc-12c samsung b/w camera.
im trying to get the wiring dirgam for a ssc-12c camera
Dec 29, 2007 | Samsung Weather Resistant Security Camera...
Looking for a manual for A Samsung SSC security system
Am not familiar with an SSC-960, there are however SVR-960 (4 versions) by Samsung.
Normally Samsung follows similar installation procedures and the differences in their model are advance features and the length of recording time. If this could be of any help, this link is a users’ manual for a 1280 hrs model. It includes installation procedures.
Alternately you can try Google for “svr 960 pdf” but when I tried it most that I can get are German language versions.
Hope this be of some help/idea.  Good luck and kind regards.
Aug 25, 2007 | Samsung Weather Resistant Security Camera...
Samsung Weather Resistant Security Camera SSC-12C Logo
4,536 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Colin Stickland
Colin Stickland
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
