Dvd error code 31 00 (not 13 00)
The dvd player shows error code 31 00 after it says please wait.  This problem has been slowly getting worse, the past couple of weeks it cleared when i turned it on and off a couple of times.  Now it won't go past the error.  Thanks
  • gctech Dec 13, 2007
    I just purchased a new DAV-HDX500... Same problem as soon as I powered it up for the first time.
  • shanego Jan 28, 2008
    it does not say anything about error 3100 all that comes up is "please wait" and it continues for as long as the system is on I have tried to disconnect the power and it still says "please wait", there is a dvd in the system and it will not allow me to get it out I do not have picture for dvd aswell.
About the dvd error code C 31 00. I just found out and fixed the problem. You must open the top of the machine and move the white moving finger that picks the dvd/cd slot back into its origional place. Via a slot on the left side of the cd compartment about an inch in. The it will then properly pick the dvd/cd that you wish. You must also open each dvd/cd drive again so that your machine will know there is something in it. YOU ARE WELCOME
Posted on Jul 15, 2009
  • bburke627 Jan 24, 2011
    how do you get the plastic cover off? I guess it's a dust cover. I don't see any slot?
No offense, but that's really not that helpful. The top dust cover comes off on mine by removing several screws on the rear and sides first, then one on the bottom. After engaging the lever that releases the disc, that only allows you to retrieve the disc that particular time, not a long term fix. Solving the long term problem is the part yet to be determined. My receiver miraculously works perfectly with no codes once I remove the dust cover, so I just set it on top. I'll eventually replace it with a samsung or toshiba since those are the only brands that have not let me down.
Posted on Dec 16, 2012
Dmr-ex85 shows u81 code and is not functioning at all, says please wait but eventually just goes onto error code. no buttons will function?
Physically unplug power from the unit for a minute or two.
Connect power cord to unit and Simultaneously Press & Hold
both the [STOP] and Channel UP [^] for 5 seconds. This will
force Eject the DVD tray. Remove any disc if present.
Cycle the power again if necessary and wait for the unit to
go through its self check cycle. If after several attempts, and
you continue to get this error, then your Ram drive may need
to be replaced.
Jul 12, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Polaroid portable DVD player error code ''bad disc''
You'd need to open the unit, and the problem is either that the laser and the tray are misaligned, which can be tricky to fix even, or worse, you need a new laser. Either way, the Polaroid dvd player may not be worth getting repaired if it is no longer under warranty.
Good luck!!
Nov 29, 2009 | Televison & Video
Starts a self check then power goes off
Not sure if this will help. My machine was stuck with a "Please Wait" message. Searched internet, many folks with problem. The fixes all pointed to 2 capacitors being blown. My brother was able to easily solder 2 new ones in and the machine worked perfectly. If you Google the name and model with Please Wait after it, you will see some of the conversations and remedies. Your machine may be heading toward this problem.
Also, beware of storing too much on your hard drive! My machine was working great after the above repair, but I believe I had too much stored on mine and I got a U99 Error Code. Service Center said it can not be repaired and THEY DO NOT MAKE THESE ANYMORE. There are DV machines with a hard drive so you can watch shows, but not to record show/movies. I make DVDs of my son's high school games. Can edit and transfer many games at once with this machine... not with any others!
Do not let this one die on you. It is priceless.
Feb 02, 2009 | Panasonic DMR-E85H DVD Recorder
WRONG Region error . Philips DVD65K
Each DVD player is designed only to read discs froma certian region of the globe, and they are labelled 1 through 6 (or ALL). Australian players are designed only to play Region 4 discs. United States discs are Region 1. It is illegal to change the Region code on a DVD player, so I can't tell you how to do it (ironically, it is the most frequently asked question about dvd players on - global world), but there are videos on YouTube that will show you how to do it - I would just enter "philips region code dvd" as your seacrh term. You won't find that exact model, but one of the codes in the video should work. Note that you will only be able to change the region code three times on a Philips - after that you will be locked out. So change it to Region 1 once, and never change it again.
-Tha Mp3 Doctor
Dec 21, 2008 | Philips PET710 Portable DVD Player
Regional code
1) Turn the DVDR3590H on, with no DVD in the drive
2) press HOME, so the browser appears
3) press PLAY/PAUSE. The display on the machine should say "BROWSER"
4) Slowly enter the following code: 159121212005255 (the numbers should appear on the display)
5) press PLAY/PAUSE.
6) Turn the player off
You might have to try it several times before the numbers will appear in the display panel. Don't enter the numbers too slowly either.
Oct 19, 2008 | Televison & Video
Hi guys,
I cant play any dvd or cd with my philips 3140 simply says ERROR.
Can someone please help?
thank you,
Jan 05, 2008 | Philips DVP3140
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
1,923 people viewed this question
