Driver's side power seat will move up and down; however, it will not move back or forward. I am looking for the wiring diagram for this. I would like to test the circuitry before spending money buying parts suggested by Ford.
Anyone have a wiring diagram (Haynes Manual does not cover it) or a link to one?
Thanks in advance!!
You could try using a voltmeter or test light to confirm if power is getting to the motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
SOURCE: 99 FORD TAURUS driver SEAT RAIL TRACK
U will need to replace the power seat transmission, the gears are most likely stripped out, not uncommon, this part is $800 so i would suggest u try to locate a used one.
SOURCE: 1996 ford mustang convertible ac blows cold only from defroster
Check the vaccum line at the vacuum distribution block (to the right of the brake master cylinder). It's the smallest vacuum hose.
Does it still blow out the floor and defrost when you set the switch to those positions or does it alway blow out the defrost no matter what? If you can get air to blow out to the floor, then it sounds like you lost the switch that controls the airflow to the vents. If it only blows out the defrost, then you probably lost the vacuum to all of the switches. When the vacuum is lost, it will only blow out the defrost. Check the smallest line on the vacuum distribution block located in the corner near the brake master cyclinder. That line provides the vacuum to control the direction of airflow within the cabin.
SOURCE: 1996 Ford Explorer - Eddie Bauer 4WD - Replace Power Seat Switch
the switch pops in or out just pull on it unless you see screws it should just pop right out theres no need to worry about the srs.
SOURCE: how do i remove the back seat to my 2000 ford
On the seat bottom left and right of center there's a release clip. (see photo) Carefully push the release with a flat screw driver and pull up doing one side at a time.
Once the seat bottom is removed there's 2 bolts holding the seat back in place, remove the bolts and lift the seat back straiting up.
