Question about Pentax Optio W30 Digital Camera
Help me i've fallen and cant get up
I dropped my camera the other day on the floor at Big Lots...Now it won't turn on.  Took the battery out and back in a few times.  everytime i do the green "on" light will come on for a second but then it goes off.  There is no visual sign of the body being cracked so i dont know why it would be destroyed...can you help!
  • 2 more comments
  • Anonymous Mar 26, 2008
    Same problem, but I don't remember abusing it.
  • underwatergi Apr 19, 2008
    I dropped my camera and it turns on for about three seconds the turns off. The only thing that pops up is the last mode that I had it in. I took out the batt and memory card out and back in hoping that would work. Nothing changed : ( HELP!!!
  • bummerdude Apr 06, 2009
    Same thing dropped it and now it turns on for a few seconds then turns back off. My theory: I think the lens got off track after the fall. Now when the camera turns on and tries to focus it realizes something is wrong and turns itself off. Anyone have an easy fix or solution?
  • John Tripp
    John Tripp Apr 16, 2009
    Yes, same problem. Called Pentax and he told me how to reset the camera. I think he really knew the true answer. Wow, thats alot of camera and cost as much to fix as to buy another. This time I will plan ahead and get one that something as simple as a control board can outlast it's cost......JT
  • 4,655 Answers
After a long study of the dropping the camera problem I am convinced that the camera is poorly designed and that if anyone that cares about quality will plan by studying ratings of various types of cameras they plan to buy and by many companies that offer such advice. (Not Ebay!) Sea Breeze
Posted on Jul 04, 2009
  • 328 Answers
Cameras are not made to be dropped but some are more durable and some just get lucky. The case does not have to crack for the camera to not work. Any single internal connection or circuit board may have cracked or come loose. You need a tech person to open it and check connections. May result in buying a new camera, sorry.
Posted on Oct 26, 2007
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
I dropped my camera and it won't turn on unless plugged in
Sadly there is nothing FIXYA can do for you here . we all have had accidents that turn out costly
Oct 10, 2017 | Kodak Cameras
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Aug 23, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
Turn on camera,lens pops out,goes in/out focus reads lens error
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 15, 2009 | Nikon COOLPIX L18 Digital Camera
My Camera turns on But will not take a picture, I push the button to take a picture and it doesnt do anything! I took the batteries out, charged batteries, took out the lens, took out the card, and put...
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 06, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Dropped SD750 on floor, now won't turn on
That's a hard one to analyze through email. A camera tech would have to use test equipment on it to see if the power section got shorted when the door opened when it hit the floor. It may not be a cheap or easy fix, but only a tech can tell. I have heard of cameras getting damaged, just from putting batteries in backwards, so a short circuit might have damaged a chip inside. Of course a warranty does not cover dropped cameras, but you might want to have them look at it and tell you what it will cost.
Sep 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Kodak Camera Frozen
It could be something more serious, or as simple as inserting fresh/fully charged batteries, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Aug 27, 2009 | Kodak EasyShare One Digital Camera
Pentax Optio W30 Digital Camera Logo
289 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
