Question about Hughes HR10-250 DirecTV / TiVo 200-Hours Video Recorder
Phsycadelic images I have a TiVo HR10. Output to my HD TV looks fine when using s-video. However HDMI outputs a picture that looks like cartoons rather than people - phsycadelic images. I've reset the receiver, changed HDMI cables and used a different input on my HD TV. No changes. However when moving the HDMI cable connection (at the plug) on the receiver, the picture improves but returns to its poor state when I stop moving it. The screws around the plug on the outside of the back panel are tight.
Most likely your HDMI card is defective. If you have a free component spot on your tv, use component. You'll get the same great picture as HDMI, just have to use 5 cables instead of 1. You also won't have to deal with the annoying HDCP problems and HDMI. If you do not have a free component slot, make sure your HDMI cable is securing (don't push hard) in the HDMI connector on the tivo and on the tv. Also, check your video settings to ensure they aren't cranked up from the factory, but 99% of the time, it's the bad HDMI card in the unit, which can be repaired. I recommend ccs corp in Indiana, I've used them in the past and they're great.
Posted on Nov 21, 2007
SOURCE:
Do you get HD quality by outputing to TV using
no ,but you will have a dvd quality picture. HD means
the picture size format usely 16:9, HDMI its a Hd
multimedia interface its HD quality to...
hope that help you..
Feb 18, 2010 | Sony HVR-A1E HDV Digital Camcorder
HDMI stopped working with tivo
If your sure there's not a problem with the HDMI cord and also the tivo box then you need to replace the small signal board Manufacturer Philips Part Number 313918888991 Description CBA SSB
It cost around 120-180 dollars.
Test your tv by using something else with a hdmi output if you can.
Oct 14, 2009 | Philips 32PF5320 32 in. HD-Ready LCD...
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
My ps3 has no picture or sound...
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
HDMI and Component Outputs do not work simultaneously
try using a digatal out cable instead of rca cables this should solve the problem!
Nov 06, 2008 | Hughes HR10-250 DirecTV / TiVo 200-Hours...
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
Aug 10, 2008 | Humax DRT800 TiVo Video Recorder
Hughes HR10-250 DirecTV / TiVo 200-Hours Video Recorder Logo
102 people viewed this question
Top Hughes Televison & Video Experts
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
