Question about Reddy Heater-30-55,000 BTU Variable
Wont stay lit
I purchased by reddy heater over year ago  30-55,000btu. It had been working fine until today. After starting heater, I  keep the button pushed in, but when I let go, the heater quits.  I have held the button for several minutes, but it still quits when I let go.  I let go very slowly but it will not stay on.  It normally stays lit when I hold it for 15 - 20 seconds. The only thing I can think of is the thermocoupler is bad. Please let me know what you think and also how to fix the problem.
Tks
Joe Mahoney
7219 Frankfort St
Navarre, Fl 32566
E-Mail    nav7219@bellsouth.net
  • nmdoug Feb 04, 2009
    I have the same problem. It had been running for up to an hour and then would go out. It would relight if the button was held for around a minute but now will not relight.
  • 1,420 Answers
Yep, sounds like you got it. Unscrew the fitting at the gas valve and take the thermocouple to a reputable Propane Gas supplier. They can match it up for you or you can order one off the internet.
Posted on Oct 26, 2007
Rheem Fury Gardian 40 gal LP water heater pilot will not stay lit
1) Clean air intake (flame arrestor):located under combustion parts and look for broken glass from TRD
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
2) Troubleshoot by type of gas control, and link to AS Smith service manuals
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Add a comment with more information
http://www.thetankatwaterheaterrescue.com/forums/forum3/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 24, 2012 | Water Heaters
Flame won't stay lit
bobdukw,
This is a classic reddy heater problem. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 22, 2010 | Reddy RLP55V Utility Heater
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Infra red heaters wont stay lit flame in the tubes
have you tried to heat up thermal couple for a couple of minutes. It takes a few minutes for the flames to actually starts heating thermal couple you might have to move thermal couple a little closer to heater flames
Jan 16, 2009 | Reddy HD30 Heater
Reddyheat rlp 100 will not stay lit, strong gas smell.
I had the same problem with my Reddy Heater PRO 100. It is the 20Lb bottle causing your problem.
I Put a 100LB bottle on and ended my problems.
Dec 31, 2008 | Reddy Heater RLP100 Portable Forced Air...
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy Heater-30-55,000 BTU Variable Logo
446 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
