Question about Reddy Heater-30,000 BTU Propane Forced-Air Heater
Reddy heater rlp 100
Heater wont stay lit when button is released. what size lp bottle is needed with this unit?
  • 1,420 Answers
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Posted on Oct 26, 2007
Pilot light wont stay lit once button is released unit is about 11 years old
call your plumber and have it serviced possibly just needs the thermocouple replaced .
Dec 28, 2015 | Bosch & Tankless LP Hot Water Heater
My reddy heater RLP 100 would not stay lit after I released the ignitor switch so I changed the thermocouple and, the thermal unit switch. The heater will ignite but when I release the knob the flame goes...
A couple of things come to mind:
Restricted air flow. Check heater inlet and outlet. Remove any obstructions.
If the heater has been used in a dusty environment, it may simply need a thorough cleaning.
Inadequate propane supply. Make sure there's enough gas in the tank to facilitate combustion.
If the tank is full, turn of the tank valve and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Turn the tank valve on very, very slowly, until it's fully open and try relighting and operation of the heater.
If you have misplaced your Owners Manual, you can find it at www.deastech.com
Hope this helps to solve your problem.
Mar 02, 2011 | Reddy Heater RLP100 Portable Forced Air...
Can i convert my rlp 30 to natural gas
No you can not convert this unit to natural gas. They do not make a conversion kit or give us any sizes to drill out any orifices.
Dec 27, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Reddyheat rlp 100 will not stay lit, strong gas smell.
I had the same problem with my Reddy Heater PRO 100. It is the 20Lb bottle causing your problem.
I Put a 100LB bottle on and ended my problems.
Dec 31, 2008 | Reddy Heater RLP100 Portable Forced Air...
Rlp 30 won't stay lit after holding control button 30 seconds
Chk and make sure the thermocoupler bulb is in the pilot flame, If it is, it is defective and needs to be replaced. Easy, inexpensive repair. Good Luck, Ned
Dec 27, 2008 | Reddy Heater RLP100 Portable Forced Air...
Reddy Heater-30,000 BTU Propane Forced-Air Heater Logo
682 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
