2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive
now, start the process
STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in!
STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons
release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart.
this works on me... good luck.. and i hope it will help you.....
Thank you ANdrew!
It really helps me today. I have the same problem. I am almost dying. Then I download the bios flash (new version 3310 ONLY for 150 or 110 aspire one, see the instruction on acer website). I changed the name and did everything as what Andrew said.
It really works. Then the Winxp starts, there still 3 programms running there!
Hope this trick can also help others in emergency.
I wonder this flash ation is just like the function of a RESET button.
CAUTION: flah bios may cause when you use a wrong version!
I am using Acer Aspire 5735z laptop.the problem is while im using voice chat my microphone is not...
(More)
I am using Acer Aspire 5735z laptop.the problem is while im using voice chat my microphone is not working.but i can hear the voice from another side.but they can't.pls advice
