Garden Logo
R
Richard melucci Posted on Feb 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Snowblower always in gear and wont throw snow and cant move when engine is off
Troy bilt snowblower wheels locked when engine is off.. While engine is on wheels are constantly engaged... Can not put blower in idle.... Wheels constantly turning...Snowblower will not throw snow... Pins are in both sides of blade... Any input would be great.
Chris Lawrence
Level 2:
Guru:
  • Expert 145 Answers
  • Posted on Apr 12, 2014
Chris Lawrence
Expert
Level 2:
Guru:
Answers
145
Questions
Helped
35370
Points
217
Service kit available for that mess of gears in the motor box(needle bearings inside the gear seize up), there is also a shear or sacrificial adapter mounted to the impeller input shaft Parts and Diagrams for MTD 31AS63EF729 2011 check around part # 7 and 15 top right hand corner. hope this helps. if this didnt help check out this web site
3 Related Answers
rwvanlue
Roland W VanLue
  • 486 Answers
  • Posted on Dec 06, 2009
SOURCE: Snowblower wheels wont engage when they are on the
1) Traction drive belt slipping or worn
a) idler pulley not fully engaging
b) cable/lever adjustment
c) spring missing or broken
2) Friction drive disc slipping or worn
a) rust on hexagon shaft not allowing friction disc to move
b) missing or broken engagement spring
3) clevis pins missing or broken on wheels
4) roll pin on drive shaft missing or broken
inside the cover for the gearing mechanisms, chain drives, gears ect.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Tim Kelley
  • 6 Answers
  • Posted on Jan 06, 2010
SOURCE: Snowblower seems weak for a 5HP
Check to see if there any surface rust inside the auger assembly. This will cause this problem. Also, you try a silicone spray on a painted surface.
ToolBoxHero
Paul Sikkema
  • 171 Answers
  • Posted on Jan 10, 2011
SOURCE: I have an Ariens 926LE
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Testimonial: "Have not tried the trouble shooting steps yet. I does make sense to me and will try them when I get home. Hope it works. Getting a lot of snow."
How do I fix my snowblower when the wheels won,t move ahead or back
Sounds like gear on axle shaft broke shear bolt or key. Take bottom plate off base of snowblower.It is ok to tip snowblown up on front end so wheels are in air. After plate is off turn wheels and see if drive gear is moving with axle. If not key way or bolt has broken off, replace and will be back in motion.
1helpful
I have a 2009 troy- bilt snowblower 10/24,and when it is under a load it does not rev-up to high to throw the snow, what causes that?
check the linkage to be sure gov is working
its not going to rev up higher ,but it should maintain speed (rpm)
be sure to match your foot speed to amount of snow trying to remove. you can feed it too fast
Oct 09, 2014 • Garden
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
My snowblower looses drive power when under a load
check drive wheel if chewed up or worn out replace
adjust cable or linkage tighter for drive
We have a yardworks snowblower and when not using the wheels always lock up. how do you unlock them without turning on snowblower.
Had the same issue and found out that the wheels lock when the motor isn't running and the accelerator handle is engaged. I still had both handles tied down from transporting home and it rolled fine after they were untied. Hope that helps
2helpful
I have a new Troy Bilt Snowblower. My father ran over a large extension cord while blowing snow, which in turned wrapped the cord around the auger shaft ends. I can now only get one side of the auger to...
Your snowblower has 4 shear pins keeping the front auger safe. Use the manual to locate them if you are unsure where they are and how to change them. Since your snowblower is new I am going to assume you have the manual.
Your snowblower came with 2 spare shearpins. Check up by the handles and see if they are still there. If you don''t have them go to your local Lowes, Sears, or MTD repair shop to get new ones. DO NOT USE STANDARD BOLTS!
The drive shaft coming out of the gear box is one, solid piece all the way across the snowthrower so if one side is turning there is a 95% chance it's the shear pins.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Troy-bilt 5524 snowblower - the drive wheels are locked. Pulled it apart and everything turns but when all gears are in place wheels won't turn - If I move the small gear from the drive it works but goes...
The outermost large gear has 'needle' bearings that will over time get snow, salt grim caught in them and they freeze up. Remove the gear and intially work some WD-40 into the bearings with your fingers. Mine loosed up fairly easy. Continue adding WD-40 to kind of rinse away the grim. Then, dry it out with a rag. I added some lithium (white) grease and worked it good before replacing. Once replaced, it will spin like a top!
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
