Sony KP-57WS500 57 in. Rear Projection Television
Problem for Sony KP-57WS500 57 in. Rear Projection Television
Picture is overlapping with a green and red color
By elmer101 on Jun 06, 2009
i pressed the flash focus botton but it did not fix it
Best Solution
posted on Jun 06, 2009
Very Helpful)
hatman1
Rank: Guru
Rating: 92%, 101 votes
The convergence output IC's need to be replaced. That is a very common problem with all projection tv's.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jun 19, 2009
Helpful)
Ecollier2012
Rank: Guru  Sony Expert
Rating: 93%, 542 votes
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Was this helpful?
Yes
No
Popular Solutions for Sony KP-57WS500 57 in. Rear
Questions and Unsolved Problems for Sony KP-57WS500 57 in. Rear
Do you recommend Sony KP-57WS500 57 in. Rear Projection Television?
Answer
Answer
sony 1994 kv 27v10 no pic, white backlite mainly at top sometimes pic returns for a while Is this... (More)
Answer
the pic is off there is bowing at the top and bottom of the tv screen
Answer
timer flases 10 times then pause then ten more no pic or sound
Answer
our colors are out of focus. lots of red and second image is shpwing
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-57WS500 57 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
