When veiwing always see double image
Up close to the eyepieces around the barrels are small screws that you
can use to "collaminate" your binocs. The screws aren't meant to be
accessed by the owner and most manufacturers cover them up with the
material that surrounds the binocs. Of course the binocs in their
current state are useless anyhow, so I wouldn't hesitate to peel up the
material to look for the screws. If you do it carefully, you can reseat
the material anyhow. Then once you locate the small screws, put the
binocs on a stand or a table outside. Focus on something far away using
one eye. Then using both eyes, you adjust the screw on the other
eyepiece while looking through the binocs. Adjust until you get a
single image. You can use loctite, or nail polish to "glue" the screw
in the final position if it is really loose.
