SOURCE: Cartridge problems with the P915 Lexmark printer.
First check they compact able once, refilled cart are recognizied
by printer,,,,
Cleaning the contacts on the cartridge carrier
Step Action
1 Power the printer/All-In-One off and unplug the power cable from the outlet.
2 Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3 Gently move the cartridge carrier into a position where cartridges can be removed.
4 Remove the print cartridges. (For information on cleaning the cartridge contacts, click here.)
5 Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
6 Repeat Step 5 for the other cartridge slot (if applicable).
7 Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
8 Plug the printer/All-In-One back into the power outlet and power it back on.
If your cartridges are not being detected when they are snapped in, do the following:
Open the cover of the printer and unsnap both cartridges.
Snap them back in after a few seconds. Close the cover.
Repeat these steps (1-2) three or more times in succession. You will be prompted to go through the menu on the printer display to finish the process. Follow the instructions displayed.
If your printer is posting a LOW INK LEVEL or CHANGE CARTRIDGE error, snap the cartridges in and out as directed above (steps 1-3). When you close the front cover, you should see the message Cartridge Change - NEW on the display.
Press Select to indicate that you have just installed a new cartridge.
SOURCE: How can I install my Lexmark P915 printer to my vista O/S laptop
Unplug the printer usb cable from your computer. To install, I suggest you use the Lexmark P915 printer software you can download from the Lexmark website. But check if your Vista is running on 32-bit or 64-bit operating system by clicking on the Windows logo Start menu > right click on Computer > Properties. For 32-bit, click on this link: http://bit.ly/9MpwNB. For 64-bit, click on this link: http://bit.ly/d4tR3d. Download and install. Follow the instructions carefully. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Testimonial: "Was great and solved"
Please visit the Lexmark website to download and install the
Lexmark P915 Printer Driver on your computer - for free. Select your operating system
> click on "FILTER" > click on the driver under Recommended
Downloads > download and execute the file. Simply follow the instructions on
your computer screen to complete the installation.
I hope this helps.
