Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Monitor problem. Monitor comes on for about a second and then goes dark at startup or cycling power switch. Turn power off, then back on ...same brief normal screen---then dark.. please help! frustrated.
  • xlr8faster Nov 05, 2007
    My monitor displays correctly, goes dark....reappears fine, then goes dark and good at a random pace. What could causing this?
    model FPD 1730
    PART/NO 7004036
This just happened to me last night.  My web research indicates that the monitor is bad...others have had the exact same problem.
Posted on Oct 26, 2007
Monitor comes on and then immediately goes dark goes off
Your monitor's power supply is probably bad. If your inclined, you can pry apart the monitor shell and replace any bulged capacitors you see on the power supply. Replacement capacitors are available from
Mar 30, 2013 | Computers & Internet
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor comes on for a brief milla second then
hold the power button for 5 sec : if the picture appears replace the button. ELSE check the chimic capacitor if damadged replace with new
Jun 21, 2010 | Dell E173FP 17" LCD Monitor
Monitor goes dark
If the power light turns yellow, there is no signal being received by the monitor from your computer's graphics card. The screen will shut off (go into idle mode), which is a low-power state, that saves energy. Check that the cable on the back of your computer is plugged into the right graphics card (many PCs come with more than one, these days). There may be one built into the computer's mainboard, and another one may be on a separate graphics card located somewhere else on the machine. Only one of these will work on startup. If one doesn't work, try the other.
Apr 23, 2010 | Dell E176FP 17" LCD Monitor
Blank screen
Possible that the HV inverter or the CFL tubes are going bad / defective. I suggest to bring the unit to an authorized Acer service center for proper check-up / test & fix the problem. regards
May 16, 2009 | Acer X221WSD Monitor
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Viewsonc VA720 Flickers On and Off Continuously
Take a look at the capacitors and see if you have any weak one. An obvious way to spot one would be one bubbled up on top. A bad cap won't always be bubbled up. The monitor probably can operate until the voltage drops under 8 volts. Also possible if power supply check out good would be a weak backlight inverter.
Apr 05, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
189 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
