Question about Car Audio & Video
ClearVue POWER BOOSTER ANTENNA
I RECENTLY PURCHASED THIS ClearVue POWER BOOSTER ANTENNA AND UNFORTUNATELY THE DIRECTIONS APPEARED SIMPLE, SO I THREW AWAY THE INSTRUCTIONS WITH THE PLASTIC.  NOW I HAVEN'T A CLUE HOW TO HOOK IT UP.  CAN YOU BE OF ANY ASSISTANCE?  THANKS, KATHIE
  • 3 Answers
SOURCE: Booster seat
Converting the seat to a booster: (Alpha Omega Elite Deluxe 2004 version, Eddie Bauer)
After all said and done, the base can probably be left on, it helps to recline the chair when the child is asleep. If you want to leave it out, the manual says the base can be removed for narrow vehicle seats or airline use. Locate the center bar at the bottom of the seat, push the tab at the end of the bar and pull the bar out. The seat can then be separated from the base. The seat has a "kickstand" that can be pulled out to sit the seat upright. Put the bar back in the base so you don't lose it.
To remove the harness, remove the base first. Then from the back of the seat, unfasten the harness from the harness bracket. Store the bracket by looping it behind and around the back spine of the shell. You can unthread the harness from that point and pull it out. From the bottom of the seat, locate the buckle's metal clip. Insert the clip up through the shell and pad, from the front pull the buckle free from the shell. Lock latch plates into buckle for safekeeping.
Once the seat is converted to adult straps don't use the latch system; hook the hooks together to keep it from swinging around, and place the top anchorage strap behind the seat with the anchor hook under the seat.
Posted on Oct 28, 2008
SOURCE: My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Posted on Dec 16, 2008
rat tails 57
  • 11 Answers
SOURCE: lost directions
go to ign.com
Posted on Feb 01, 2009
SOURCE: Need help with Moulinex yogurt maker, have no directions in box
Moulinex International website:
Moulinex Yogurt Manual with instructions
http://www.moulinex.com/NR/rdonlyres/CDDE28CA-8575-43DD-BB64-46E694EF10B9/18817/YAOURTIERE20DJC1_DJC2.pdf
Posted on May 07, 2009
  • 4 Answers
SOURCE: I'm trying to listen to
Check and see if you might have a hook up wrong.
Posted on Aug 06, 2010
Is there a antenna or a booster that i can use in the house
There are many antenna systems available for Off-the-Air broadcast TV. It depends on space available mainly. There are internal (inside the home) and external mounted systems. Some external antenna can be mounted in the attic as well. External antenna are usually larger and cable of receiving signals from longer distances. They are either directional (point in one general direction at a time) ir omni directional (can receive signals from 360 degrees without physically aiming or pointing the antenna). They also can come with amplifiers/signal boosters, motors (to rotate the antenna for better recepton without manuall shifting it yourself). You can add splitters ti provide signals to more than one TV at a time. The number if channels you receive can depend on many variables so, depending on your location, how far away from the broadcasting antennae you are, and how you mount your antenna, the number of channels & quality of receive signals will vary.
Good news is there are websites on the Internet that can help immensely, so you don't to hire an electrical engineer!
Apr 25, 2017 | Televison & Video
Where can I get a vintage Radio Guide from.
Simple SEARCH: https://en.wikipedia.org/wiki/Roberts_Radio contact company direct! Over 80 years making radios. LEHenson@msn.com 704-470-9020 73's!:=)
May 18, 2016 | Radio Communications
Having trouble connecting to analog TV in my RV.
is there an input setting in the main menu .to receive signals it has to be on antenna or air .then do an auto channel scan.try it without the convertor box .
Oct 04, 2015 | Televison & Video
What antenna works on Toshiba 20VL43U? I purchased Mediasonic Homeworx HW110AN Super Thin Indoor HDTV Antenna - 25 Miles Range.
I recently went through a whole song & dance about HDTV antennas for my RV. I bought two different directional high-gain antennas, only to find that they wouldn't even receive signals at my home! When I'd reorient the antenna and initiate another channel search, I would sometimes get ONE or TWO channels... then I'd lose them when I'd try to reorient the antenna.
What I figured out is that DIRECTIONAL HDTV ANTENNAS ARE, ESSENTIALLY, WORTHLESS. There is really no way of knowing precisely which direction the broadcast towers are and, even if you knew, they will not all usually be clustered in one small area... they may be scattered here & there around your area.
What I eventually did is bought an OMNIDIRECTIONAL HIGH GAIN ANTENNA, which was no more expensive than the DIRECTIONAL antennas I tried. Did a channel search, and got almost all of the channels in my area!
Any omnidirectional HDTV antenna will work with your television, but I'd recommend buying the one with the highest GAIN (expressed in "dB" or "dBi" with the highest number being best). Try to find a POWERED antenna with an internal SIGNAL AMPLIFIER.
Also, if you live far away from broadcast towers as I do, you may wish to consider adding an additional SIGNAL AMPLIFIER as well.
May 21, 2015 | Toshiba Televison & Video
Where can I get assembly instructions for the rubbermaid 60" garment organizers? I was recently reassigned from one military post to another and the movers disassembled the closets, but I threw away...
I saw that you put this problem under as a shoe problem, but it is more of a assembling or hardware type problem. Changing the category from a show problem to something more suitable can help you get the problem answered sooner and by a non shoe expert.
May 19, 2011 | Clothing Accessories
I am thinking of purchasing this tv for a person who doesn't have an outside attenna and is too poor to purchase cable or a dish program. Can this set, a 22in. 720p model, work with an inside attenna? Is...
Any TV that has a Coaxial input can connect directly to an RF antenna. If this person lives near a large city, its likely they will receive more channels than if they live somewhere remote. Perhaps an antenna with a powered Signal Booster will improve the signal. Neither are included so I think Radio Shack has a good selection.
Jan 17, 2011 | Coby Televison & Video
I'm trying to set the digital channels on my durabrand tv and i get the message that digital channel signal strength is low. what do i need to do?
If you are using a regular antenna to receive the signal, then you would need to either find a signal booster of some sort, or improve the antenna. There are many antennas out there for the digital era, most of them are set-top multi-/omni-directional ones, but they have their limitations. Unfortunately to get a better signal, typically an outdoor antenna is needed, or a large expansive one in the attic.
Nov 19, 2009 | Durabrand DWT1905 TV
Low signal strenth...looking for an antenna for a wireless connection for a laptop. Where can I find an antenna ? Local stores ? Walmart, Bestbuy, OfficeMax ? etc...
If you look on eBay there are hundreds of add on aerials that give you plenty of signal boost. I bought several recently and they really do work. I even added a +24dB booster on my main wireless hub now I can really use the power of wireless and roam away from the house and the office!
Just enter "wireless aerial" or "wireless antenna" as the search term and you shoud literally get hundreds of results.
Sep 12, 2009 | Computers & Internet
Winegard digital to analog RCDTO9A
This is in an RV I gather? You do realize even with 2 converters, you may only be able to watch 1 channel at a time, as in same channel on both TV's?
Jun 26, 2009 | Audio Players & Recorders
My son threw the instruction booklet away. we are
unfortuantely, no. try contacting the game's developer or the shop/business from which it was purchased to look for a spare. check websites like "gameFAQs.com" for a general overview of controlls and some playthrough help if necessary.
Jun 12, 2009 | Nintendo Video Game Consoles & Games
Car Audio & Video Logo
867 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
