Question about HP DeskJet F380 All-In-One Printer
F380 all-in-one scan problem
Cant scan photos press scan and nothing happens
  • 4 more comments
  • otters Feb 11, 2008
    put document in the top face down. Press scan. Nothing? Am I being really dumb..
  • gilbertjr Feb 25, 2008
    I try and scan by pressing the "scan" button on the printer but nothing happens. I checked to see if it was connected and installed into my computer in the control panel and it was. I created my profile and ran the scan test and everything seems ok. I tryed to scan again and again nothing. Only thing the scanner (printer) does is blink the power light.
  • Vlakvark Apr 11, 2008
    The scanner on the HP Deskjet worked for a few weeks and then stopped. Re- installation did not help. Drivers I dowloaded did not help.
    Press on the scan button and the power lamp only blinks. Seeing the number of people with excatly the same problem, I can only conclude tha ttis is a serious bug in this printer.
  • AngelMAk13 Apr 11, 2008
    I have the HP Deskjet 380, and it's worked fine for a long time. I just put a new ink cartridge in, and it printed out a test page that said to scan the page. I tried to scan the test page, but it the red error 'E' was flashing, and it wouldn't let me. The printer works fine, the ink cartridge is in correctly, however because it won't scan the test page, it refuses to print!! The printer is definitely connected, but it can't detect the scanner. I have tried to scan the test page over and over again, when I press the scan button, the power light blinks it makes a small noise and then nothing happens. Any help would be greatly appreciated!! Thanks
  • Anonymous Aug 29, 2008
    it just doesn't work i hit scan and it says to scan stop all of uses of the printer and i do and nothing happens
  • Anonymous Feb 15, 2009
    The same problem to me, I push he scan button and nothing happens only power led is blinking
I have this problem w/a different printer adding it to a computer w/OS Vista. Go to Start, All programs, Accessories, Paint and open that program. Click on File and then From Scanner or Camera. Make sure your all in one is turned on. Unfortunely, there is no fix to make the scanner button work if it is not compatable, such as my 'all in one' w/Vista. Hope this helps. Linda
Posted on Oct 26, 2007
Thanks for info on HP Deskjet F380 Mrs RRP - this solution also works from Photoshop! YAY
Posted on Feb 12, 2009
It worked on my F380!
Thanks so much...
Posted on Aug 12, 2008
Hey thanks MrsRRP... Thought it's busted or something... :)
Posted on Apr 10, 2008
By paint , i can't click on scanner or camera?
and i have the same printer ( F380 )
Posted on Mar 18, 2008
Thanks.
Posted on Feb 18, 2008
SOURCE:
How do I scan docs to my PC with using Canon MP210 Pixma? Upon scanning, I am asked to chose a program, but how do I know which one. If I click on PDF, nothing happens. What do I do next? Nothing...
Open Solution menu from your desktop and choose Scanning Photos. Now put you photo on scanner board and press preview from your solution menu. After preview completing press scan... thanks
Aug 27, 2011 | Canon PIXMA MP210 InkJet Printer
HP Deskject All-In-One Scanner Problem
try from program if you have it installed on your computer, look in my documents , my scan directory that is in most cases default directry for scaned files. But try from program ( software which you have with your all in one)
May 08, 2009 | HP DeskJet F380 All-In-One Printer
Scanning
plz check in my computer is your scanner is visible, if yes then right click on the scanner and select scan and follow the on screen suggestions,
if your scanner is not visible in my computer then you have to install it with the cd which come along with the scanner
Dec 11, 2008 | HP DeskJet F380 All-In-One Printer
Scanning a photo
Make sure you have the HP imaging software installed and running first if you dont you can download the Vista version HERE that should do it
Jun 30, 2008 | HP DeskJet F380 All-In-One Printer
HP F380 not scanning
This has happened to me on several occasions with a couple of different HP all-in-one scanner/printer's. The HP driver/program itself may be in a phase where it's attempting to complete a scan, which would prevent you from scanning anything else. You can confirm whether or not this is the problem by restarting your computer and attempting another scan. You'll get an error message saying the scanner is currently in use. You may want to try to completely remove the installation files for the scanner, and reinstall either from the disk or let windows install it for you via "plug and play". Then update the drivers from hp's website. See if that resolves your problem.
Oct 05, 2007 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
1,014 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
