Question about iRiver X20 MP3 Player
How do I delete voice recordings from my x20?
How do I delete voice and audio recordings from my iriver x20?
  • Anonymous Oct 08, 2008
    can u do this without pc? Anyone?
Plug into pc and delete files via pc
that worked for me
Posted on Nov 06, 2007
Song names in X20
i think you should try this...
if you dont already, download iriver plus 3
install it
open iriver plus 3
plug in iviver
go to tools>Portable Device>Disk Initialization
this should format your iriver and replace all the original files
i reccomend only putting music, video, pictures and ebooks on via iriver plus 3
and also please make sure you safely remove the iriver each time you connect it to the computer
if you dont, there is a chance that you will screw your iriver, you may have heard of the "building library" problem, which nobody has found a solution for yet.
i hope this helps you!!
good luck!
Jun 06, 2009 | iRiver X20 MP3 Player
How can i delete my music from mp3/x20
1. connect it to your computer
2. u have a few options
  • Manually search the MUSIC folder of your x20 and delete the songs.
  • sync it with a program such as iriver 3 plus or windows media player and delte it through the program
  • reformat if your looking to delete everything
hope this helps!
Apr 07, 2009 | iRiver X20 MP3 Player
Deleteing voice recording
If you can connect it to a PC with XP on it, and have an iRiver Music Manager; once your device is recognized, you will be able to manually manage files on your iRiver, including deleting any voice recordings on it.
Oct 30, 2008 | iRiver iFP-895 MP3 Player
Iriver X20 switches off when using FM Recorder
there may be a problem with the menu files...
Aug 30, 2008 | iRiver X20 MP3 Player
Iriver X20 database full
does the message stop you from using the iriver?
if it doesn't then there's a format function on the iriver in the settings menu...
if it does then there may be a problem with the usb connection...
either the iriver isnt responding or the computer can't read it!
for the user below there is most likely a format will fix it...
Aug 01, 2008 | iRiver X20 MP3 Player
Folders inside my IRIVER X20 no longer recognised!! HELP PLEASE!!!
Try making a new folder, under the same name as the ones lost, or missing. Since the X20 is flash memory based, you may have had some of your data go randomly corrupt. You MAY have to start things over. Sorry! Good Luck!
Apr 10, 2008 | iRiver X20 MP3 Player
Transferring recordings from iRiver x20 to PC
Yes, it should work if you connect to the pc then click on my computer> iriver> then find the recordings and copy and paste them to a folder on your computer.
Jan 05, 2008 | iRiver X20 MP3 Player
Downloading movie length DVD to iriver x20
Yes, you need to convert all your movies to a format iRiver and understand and play.
Here's a link:
Movie Converter for iRiver and instructions
I'm not sure whether Movie Converter supports original DVD files. If that is not the case, then you'll have to convert DVD video into a format that iRiver X20 can use, and then feed that new video to Movie Converter.
However, that would be a bit redundant: to save on time and quality, you could use other video Conversion tools, such as SUPER:
http://www.erightsoft.com/SUPER.html
After loading your DVD, you set the parameters to mirror those accepted by your iRiver model. In case of iRiver X20, those parameters are:
Extension: AVI [[also known as container]]
Video Codec: WMV9 SP, MPEG-4 SP [[MPEG-4 = XVID, DIVX]]
Video Resolution: max 320 × 240
Video Framerate: max 30 fps
Video Bit Rate: max 512 kbps
After successful conversion, upload your new video file to your iRiver X20 and play it back. If it plays [and plays correctly] - then congratulations - it works! If it does not play, then you might have made a mistake while setting the output parameters in SUPER.
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
IRiver ifp-700 record error
upgrade the firmware should fix the problem
Jun 26, 2006 | iRiver iFP-795 MP3 Player
iRiver X20 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
