Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic Projection T.V.
My T.V. cuts on sometimes and when it does it may stay on for a few mins. then cuts back off.  I have noticed that when it cuts off the power button blinks about five times then turns off.  I had some water damage in my basement and when I had it looked at it wouldn't even come on.  They said that it needed a PS/SWEEP BD.  Then I took the back off a noticed a125v 6.3A fuse and took it out and put it back in and then the T.V. started working for a few mins. then cuts off.  Is there something that I could do or do I just need to replace the fuse or do I need a new board and if so is it something I can do or do I just have some moisture in the back of it.  Its a panasonic projection model #PT56WX53(56inch). Can you help me.
    Genius:
  • 1,139 Answers
Hello icdsr,
Let me start off by explaining what is happening. You have a component that has become thermally sensitive meaning that as the component heats up it begins to malfunction. This sometimes happens as the result of a catastrophic event to the TV such as powering it up after a foreign substance has been put on the circuit board and a short has occurred. Now the swapping out of the Power Supply/Sweep board is the quick and fast thing to do (the only option given by "TV Repair" shops these days, sad but true) it is not the only option that is possible, but you are going to have to do some looking for a shop that does component level troubleshooting. There are some things you can do, but I would suggest that you have a qualified TV repair person work on your set because of the dangerous voltages that are present in the sections you will be working in if you try to do this yourself.
Ok first dry out the set using a hair dryer on high to do this, and don't have the set plugged in.
Wait for a day or two after drying out the set to plug it back in.
Turn on the set and wait for it to cut off.
When it cuts off notice if you heard a clicking sound prior to it cutting off.
If you hear this clicking sound this means that the shutdown circuit senses an over-current condition and is shutting down the TV.
Once you have determined this you will have to have these following items.
1) a schematic
2) a multimeter
3) a flashlight
4) an isolation transformer
5) an oscilloscope
6) a High Voltage probe (both 1000v and 40Kv type)
7) freeze spray
8) heat gun or hair dryer
These items will help you in troubleshooting this problem. If you do not know what these items are, I would not advise you working on this set yourself and the option of getting a shop that does component level service is the best option for you.
How ever if you want to do this yourself get these items and I'll be glad to walk you through the process.
This are the first things you must do:
Plug the TV into the isolation transformer and the isolation transformer into the power outlet on the wall.
Turn on the isolation transformer and set the voltage to about 90Vac (not 110Vac or 120Vac).
Examine if the set turns off or not over time (if it does this will give you a window in which you must use the schematic and your other equipment to find the area that is causing the problem (this will take some time and some knowledege).
After you find the area you then will use the freeze spray and heat gun to stress the components in that area, the heat gun should speed up the shut down process, and the freeze spray should make the on time increase, this allows you to narrow down the area to a single component or components.
This is the basis of what you must do if you plan on doing this yourself.
I wish you well,
Thank you,
Shuttle83
Posted on Oct 28, 2007
Panasonic 60" LCD Projection TV Turns off every 1-2 hours
What is the model# of your TV?
Do you see any blinking (LED) lights on the front of the TV?
How many blinks?
Which LED light is blinking, Power, timer or lamp?
Nour Sabre
www.aaatvservice.com
Nov 15, 2011 | Panasonic Televison & Video
TV cuts itself off
It may be overheating. Check the temperature with your hand by placing it over the fans/slots to feel for any excessive heat. If it won't turn back on until it cools, then it's a heat issue. You could help that out by using fans to circulate the air around the unit, trying to keep it cool by moving the hot air released from it and pulling in cooler air. Other than that, there may be a short somewhere, or maybe even a broken fan.
Jun 05, 2010 | Panasonic PT-51HX41 51" Rear Projection...
My panasonic pt50lcx64 will not stay on, sometimes wont even turn on, but when it does, it lasts about 5 min then cuts off and the yellow light blinks 2x every 5 sec
Try typing your model tv along with the words "trouble codes" This could be a code 22 or a 2. Sounds like a bad connection or bad component failing such as capacitor or resistor. The tv may be shutting down as protection against what it senses as a power supply failure.
Jan 08, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
Oct 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
1992 model Rear Projection Pioneer power supply?
take the power supply board out and look for bad solder joints and resolder them. anything looks questionable just solder it. the power supply board cost`s 350 and up new. just dont bridge two solder joints that are not supposed to be. im in the process of fixing mine. mine will power up now that i did that but the ic`s are bad now so i have to replace them. they control the color convergance. you might have to do the same as well. get the stk392-180 instead of the inferior 110`s. hope this helps.
Oct 02, 2008 | Pioneer PRO-119 60" Rear Projection...
TV goes to standby mode
kindly check the capacitors on the low power section.....
Jan 29, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Tv cuts off and on.
Sounds like a bad SSB(small signal board) module. Better take it to a RCA AUTHORIZED service center.
Sep 06, 2007 | RCA D56W20 56" Rear Projection Television
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
