Question about Durabrand W600 Shelf System
Cd drawer won't open
Brand new right out of the box.  the cd drawer won't open.  is there a screw or something they did for shipping that needs to be undone?
  • 1 more comment
  • Anonymous Nov 10, 2007
    THERE IS NO PLASTIC COVERING THE DRAWER. AND DON'T HEAR NO MOTOR RUNNING TO TRY TO GET IT OPEN. PLEASE HELP I BOUGHT THIS FOR MY GRANDSON WHOSE BIRTHDAT IS NOV. 12 AND I WANT TO MAKE SURE THAT IF WORKS
    DURABRAND 6 CD STEREO SYSTEM---CD DRAWER WILL NOT OPEN
  • horses57 Mar 09, 2008
    I also purchased this same stereo. Durabrand W600-S. The cd drawer will not open. Can you solve this problem?
  • 328 Answers
No, unless a piece of clear plastic is covering it. If you can hear the motor and see that it is trying to open, it may need a very gentle pry with a plastic butter knife. I do not recommend that unless there is no warranty. I would just bring it back to the store where you go it from.
Posted on Oct 25, 2007
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
I have a brand new emerson 3 speed record player, amfm radio, cd player combo. I am having trouble with the turntable rubbing even after we tighten the shipping screw down
Shipping screws are used the hold down the turntable during shipping.
These shipping screws need to be removed after shipping and installation.
Nov 19, 2012 | Emerson 3 Speed Vinil Classic Lp Turntable...
I have a Phillips model 601/25 CD player and the CD drawer won't open - it makes a whirring noise but refuses to open.\r\n J A Adamson <jadamson35@gmail.com>
The rubber band has stretched with age. Easy fix, take cover off (several screws around the case) and band is easily accessed. Even a cheap elastic band will work as a replacement for now, it only opens the drawer mechanism, no effect on sound quality.
Aug 20, 2011 | Philips Audio Players & Recorders
I have a 4 draw Plano Tackle box as I have something stuck behind I can't close bottom draw,can you tell me how to remove draw as I've tried and cannot remove regards Sno
Use a long flat blade screw driver with a 1/4 inch blade. From either the right or left side, with the top drawer fully open, take the screw driver and place the blade between the inside of the outer casing and the drawer guide and gently pry the casing away from the drawer guide and pull the drawer open until you release the side catch on the drawer. You only need to free one side, and the drawer will sort of pivot out and the other side will be free at that point as well. Repeat for the rest of the drawers except for the bottom drawer which you will be able to access anything behind it as the upper drawers will not longer be blocking access when removed. I had a small bag of sinkers sitting on the bottom.
Feb 16, 2011 | Plano Four Drawer 757 Guide Series Tackle...
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
Need to replace cd player in Compaq persrio 700 how do I do it? no screws in hinge covers?
Laptop off, remove the AC adapter, (Charger), if installed.
Remove the battery. Turn the laptop over so the bottom side is up.
Face the optical drive towards you. (CD drive)
See how there is a rectangular looking panel, on the bottom of the laptop? (Looking at the CD drive, the panel is over the CD drive. Bottom side of laptop)
See the single Philips head screw in the panel, towards the left corner?
Remove it.
Now take a paper clip, and bend it out straight. Make a small U-shape on the end of the straightened out paper clip, so you have something to hang onto.
On the drive tray that comes out of the CD drive, is a small hole. Insert the paper clip straight in.
This is a manual release to open the CD drive tray.
Gives you something to hang onto, to pull the CD drive out.
To install the new cd drive, (Player), just reverse these steps.
[Open drive tray. Slide CD drive in. Replace screw]
Nov 24, 2009 | Compaq Presario 700 470024-192 Notebook
I have a Yamaha CDC-80. The CD drawer won't open and it makes a noise like it is trying to open, but is stick
Most probably, a rubber band that drives the drawer open is too too old. If you cannot find a new rubber band, a cheap and dirty solution just using a screw driver to pull out the drawer. BTW, I am having the exact problem, and I am still looking for the right rubber band. Hope it helps
Oct 26, 2009 | Yamaha Audio Players & Recorders
Durabrand W600 Shelf System Logo
172 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
