Question about Acoustic Research AW-721 Consumer Headphones
Sound from only one headphone
I am only getting sound from one headphone. I have checked the balance on my receiver, etc. but it is not that.
I purchased an AW 771 set in "as is" condition which on arrival produced output only from one side. Repair was effected by removing 8 phillips screws, 4 from each side, concealed under the ear-surrounding doughtnut-shaped cushions. To expose those screws, the ear cushions must be pushed from their center toward the outside. Black screws in back holes surrounded by black acoustically-transparent cloth does not make them obvious.
I used a volt-ohm meter to find a discontinuity at a failed solder connection. Resoldered that connection, rechecked electrical continuity to be certain all connections were good. Tested with batteries installed using an audio input. Both sides produced sound. Replaced screws and they have performed very well since then.
I hope this Model AW771 experience is helpful in restoring your AW-721 to working order.
John
Posted on Feb 13, 2008
Sta 3190
Check amplifier IC, check all board solder for dry one's.
Feb 12, 2014 | Audio Players & Recorders
Sound coming through right headphone, but not through left. Sound also not coming through left speaker. Help?
are you adjusting sound through the windows controller or the application you're playing music through? there are a few things that could affect that, there's also the actual sound setup where you can change your setup i.e. surround sound, single speaker, headphones etc
Oct 02, 2013 | Toshiba Satellite Computers & Internet
Sennheiser hdr 160 will not pick up the signal from the receiver
assuming the battery is charged, have you tried to switch to a different frequency band, etc.?
check page 28 of the user manual for possible actions when there is no sound in the headphone.
Oct 12, 2011 | Sennheiser HDR 160 Wireless Headphones
I have a Technics receiver model SA-EX300. I am trying to use the headphones and I am only getting sound to come out on the left side. Not sure what the problem is. The balance is in the center.
I'm assuming you are pushing the jack all the way in.
Try other headphones. If it's the same then the contacts inside the socket are defective and the entire socket will have to be replaced
Aug 30, 2011 | Audio Players & Recorders
I am trying to figure out how to connect my ipod to my Yamaha htr-5930. Can I do that through the headphone jack, or through the aux jack? Is there anyway I can do this? Thanks! nickrd83@gmail.com is where...
Use a 3.5 mm to 2Male RCA cable. Plug this into an AUX or CD input in the back. Adjust the volume on the iPod as well as the master volume to balance out the sound. The headphone on the receiver is output only.
Apr 12, 2011 | Yamaha HTR-5930 Receiver
Sound went out today. Mute is not on, and all
Does it think you have headphones connected? If you have headphones, check to see if they have sound output.
Jan 26, 2010 | Denon AVR-4308CI Receiver
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
Headphones only have left channel on Denon AVR-588 Receiver
Hi peroty,
Two suggestions for you.
1. If you look at the headphone jack connecton do you see one or two black O-rings or black lines on the jack. If you only see one they are Mono headphones and you would only get sound out of the left side. If there are two black lines they are stereo headphones and you should get sound on both the left & right sides.
2. If after checking the headphone jack connection and there are two black lines on it then I would suggest try a different pair of headphones to see if a different set of headphones works fine.
If a different pair of headphones works properly the original headphones may be bad. If neither set of headphones work properly it may be the reciever that may need to be repaired.
I hope it's not the receiver, but let me know if you have questions.
Matt @ OneCall
www.onecall.com
twitter.com/onecalldotcom
Nov 25, 2008 | Denon AVR588 Receiver
When i plug my headphones into my gateway dx only one side of the headphones works
Try your headphones on another radio/receiver to check and see if it is the headphones that is bad. Usually, this happens when a wire comes loose on the headphones.
If the headphones works, then go to Control Panel >Sound and Audio Devices > On the first page, click the advance button > Along the top you will see Wave,Line in etc. Make sure that the balance is set in the middle, esp.on wave and line in.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 16, 2008 | Computers & Internet
Hi, my sansa e250 has sound come out of only one head phone no matter how many headphones i try the same happens
The jack in the e250s is not made of adamantium, so it can actually go bad; however, if you try different headphones and thus determine that either:
  - All the headphones simultaneously went bad in one side
  - Your left ear has issues
  - The Sansa is only cranking out one channel; and
     -the jack feels a little off, or
     -perfectly good mp3s are being played off-balance; AND the balance has not been misconfigured in Settings.
...well then, the plot's moving forward and you can get your ear fixed, or stop the cat from killing your headphones, or re-load Sansa or Rockbox.org firmware, or fix the Settings, or see to the appropriate repair to the jack (depending on your warrantee status and skill with soldering irons and ordering off Jameco.com etc.)
Feb 21, 2008 | SanDisk Sansa e250 MP3 Player
Acoustic Research AW-721 Consumer Headphones Logo
289 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
