Question about Sharp R-1500 Microwave Oven
Sharp r-1514 microwave
When the door is shut the microwave fan turns on but does not do anything else help
  • Anonymous Mar 24, 2014
    Shut the door and microwave turns on
    Shut door and it turns on and wont shut off
  • Sharp Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food / grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 05, 2007
    Champion:
  • 225 Answers
Check control circuit and related circuit.
Posted on Oct 28, 2007
Turn off sound
you must test the speaker with VOM continuity 2) reset the microwaves disconnect the power cord by 40 seconds and try again. 3). Defective/damaged touchpad.
God bless you
Jul 29, 2013 | Sharp R-1514 Microwave Oven
Display panel r-1514
Possible that the control pad or the main board or the processor is faulty. You can remove the top cover after disconnecting and remove the front panel, check for insects within that have nested , if so clean the board and reset the panel connection. If not you can call for help to Sharp support at your place.
Check website : Sharp
Jan 31, 2013 | Sharp R-1514 Microwave Oven
Sharp 2010 turns itself on, fan runs but does not microwave
The repair or replace decision depends to some extent upon age and repair history.
Oct 04, 2017 | Sharp R-1210 Microwave Oven
Sharp R 1514 fan button
The only two springs I know of in this model are for the door open button and the door latch.
We have a similar model's service / repair manual and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly and troubleshooting tips.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
If you have a bad fan button, you would need to order a new select button assembly.
The part number is JBTN-B138MRF0 and you can order it here.
If you need other parts for this model, you confirm part numbers and order them from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Jan 24, 2009 | Sharp R-1514 Microwave Oven
I have a sharp microwave oven R 1514. there are 4 buttons on the front and one is broken, will not pop back out. I bought new springs and need help with the installation
It looks like you need to remove the unit from the wall, remove the outer cabinet sheet metal, then remove about 6 screws from the backside of the control panel.
You should be able to tell as you get in there what needs to be removed.
But it doesn't look like you can access to replace without taking the outer cabinet off.
Interior Microwave doesnt come on..Burned out?
If it doesn't have a door you have to remove the cover. Its likely a special microwave bulb and the socket will have to be replaced with the bulb. the bulb is built onto the socket.
Jan 14, 2009 | Sharp R-1514 Microwave Oven
Stops cooking
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 04, 2008 | Sharp R-1500 Microwave Oven
Microwave does not turn off
You can get Sharp parts from Tritronics at http://www.wehaveparts.com
Oct 23, 2007 | Sharp R-1500 Microwave Oven
Fan runs when door is closed - no heat
This is normally 1 of the interlock door micro-switches not working.
Jun 20, 2007 | Sharp R-1490 Microwave Oven
Sharp R-1500 Microwave Oven Logo
70 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
