Question about Memorex MVD2042 DVD Player
My dvd player stopped working and all i want to do at this point is remove my rented dvd.
The player does not work. all i get is the standby light and nothing else works.
can anyone tell me how to remove my rented dvd from this memorex mvd2042 dvd player.
If you just want to take out a DVD here's what to do:
1.Take off the top cover:
- remove five screws on the back (indicated by little arrows)
- remove two screws on each side (there are only two, this should be obvious)
- when looking at the back of the unit, slide it up and towards you.
You should now be able to see your DVD. However there is a piece covering it.
2. Take off the top of drive:
- remove two screws, (one on each side). They are very small (probably black) and on the top of the cover, on the far left and right. They might be hidden under small rubber squares. If so, just peel the squares off.
- The cover should come right off.
- lift out the disc
3. Reassemble
good luck,
tir38
Posted on Jan 18, 2008
My friend took out the dvd player so the light stay on an when i tuurn it on it waits a sec then does red then green screen an goes to standby
The TV is indicating that a part of it is not working, like the dvd player that is missing. Modern electronics go through a set of tests and if a fault is found the stop working. Replace the dvd player, or get the set to a repair shop.
Apr 30, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Constant standby mode on philips DVD player
Hi Johnny
Please follow these steps (even if you are sure you have done them correctly :)
1) Check if something is blocking the path between the remote and the IR sensor on the DVD player.
2) Check your remote control batteries to make sure you have fresh batteries inside(try with new ones to be sure)
3) Make sure that you have inserted the batteries according to the polarity that is instructed.
4) Remove all the cables but the power supply and try to see if it works. If it does you have some faulty cable which should be replaced.
5) At last if none of the above points helps then either your DVD equipment or the remote control is faulty. You may contact your vendor demanding you guaranty wright or a service shop for diagnose and repair.
Finally , please don't forget to rate my post.
Wish you best of luck.
Best Regards
XyFinx
Dec 14, 2013 | Philips DVP2880/F7 DVD Player
Can't get green standby light to stay on, so can eject DVD from combined TV and DVD player.
First try unplugging and plugging back in then remove caseing and insert paper clip under locking mechanism and hit eject...your locking mechanism signals that there's no cd in it and so to it there's no dvd or cd...hope that helps:)
Jan 04, 2012 | Televison & Video
Standby light is blinking red will not open dvd or play at all
in a situation like this, there are only a few things you can do.
unplug the unit and wait for an hour or 2, and plug it back up and see what happens. if the unit is making any unusual noises (listen carefuly to it) then it will more than likely need to be repaired.
depending on the price, you might just consider going and picking up a cheap dvd player from wal-mart or something.
Sep 24, 2009 | GPX D1816 DVD Player
DRC277a red light only
The red light on my player is on when the unit is off and it is on when in the standby or play mode.
Jan 14, 2009 | RCA DRC277 DVD Player
Memorex DVD player won't work
the standby light switch is your on/off switch as well......
Nov 18, 2008 | Memorex MVD2042 DVD Player
FAC-FC7 DVD player is locked and the Standby indicator flashes
I had the same problem and searched FIX and found a solution for a Phillips DVD player that worked on my Sony DAV-FC7 dvd player. Someone posted that they called their Phillips Tech Service and was told to (a) unplug the dvd unit from the wall and wait 20 seconds,then (b) press the standby+plug the unit back into the wall at the same time and hold for 10 seconds. I did this for my Sony DAV-FC7 which would not power on nor eject (just red light on). IT WORKED!! after doing these steps, my SONY powered on and the rented DVD ejected. The dvd palyer works again. Thanks fellow FIXYA "posters".
Nov 12, 2007 | Sony DAV-FC7 System
Coby dvd player
do you see the laser light come on when the disk spins if not it has probably lost power or failed, if so sometimes the laser head gets moved to close to the drive mechanism and the motor cant pull it out. i have found several of these that had this problem.
Oct 19, 2007 | Coby DVD-207 Portable DVD Player
DVD (JVC XV-S502) Does not eject dvd. Word "lock" appears in screen
hey, this happened to me too. what you have to do is put it in standby mode, then press and hold the eject and stop button on the actual dvd player, the remote wont work doing this. this is how you can unlock and lock the dvds into the dvd player. why this is a feature jvc thought this needed im not exactly sure, but thats how you fix it.
Aug 11, 2007 | JVC HR-XVC19S DVD Player/VCR
XV-N322 - Lock will not unlock
My problem was fixed by...having the DVD powered off, holding down the stop button on the player and hitting the power button on the remote.
Good luck!!
Jan 22, 2006 | JVC XV-N320 DVD Player
Memorex MVD2042 DVD Player Logo
269 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
