Question about Gateway M675 Laptop
A disk read error
When I first turn on my notebook I hear alot of clicking (I thinks it's the hard drive) then I get a blank screen with the following: A disk read error occurred Press Ctrl+Alt+Del to restart.
Tried it several times comes back to the same message.
Is it possible to get to safe mode?
  • nomomoney348 Jan 27, 2009
    a disk read error occurred press cnt alt del to restart upon boot
    is it the hardrive or how do i do a reisnatll do i need a boot d ?
I have the same problem, i guess you should take it to PC WORLD for them to take a look at your pc/laptop, however it could be a boot sector virus.
Posted on Aug 23, 2008
    Brigadier General:
  • 6,966 Answers
The "clicking" and "disk read error" indicates a hard drive failure.  When the PC boots it can no longer read some files from or the entire HD.  The corrective measure would be to replace the HD and install your OS and programs. Alternately, you may try and reformat then re-install but then you would be operating with an unpredictable storage media and perhaps prolonging the inevitable.
If your reason for Safe Mode is to be able to access your files for purposes of backup, the constant trying/on-off just might worsen the condition of the HD. You can still try recovering by installing the HD in question inside a 2.5 enclosure to USB and install it as a removable device in a 2nd PC where you can try recover files.
Should you install a new HD and install the OS in your Gateway, you actually can use that to try and recover from the old HD. Recovery is 50/50.
Good luck and kind regards.
Posted on Oct 25, 2007
2 Suggested Answers
  • 37 Answers
SOURCE: when my thinkpad boots up I get the following
Sounds like a problem with your hard drive, you could follow this guide to make a bootable diagnostics CD to try to determine the exact problem.
Posted on Jul 28, 2010
1790: disk 0 error
Your hard drive has failed to load.In the bios did it show the hard drive?Can you hear the hard drive?Do you hear a clicking sound?The are signs that the drive is failing.Try to boot to a windows cd, see if this will allow you to see the hard drive.If you can chances are you might be able to get your data from the drive.Once you do so replace the drive.
Good luck
Sep 25, 2009 | Compaq Armada E500 Notebook
Insert your Windows installation disk and select Repair Windows rather than Install. Hopefully it will allow you to boot properly.
Sep 23, 2009 | Dell Inspiron 6000 Notebook
Blank screen
Any hard disk that makes clicking or metallic noises is faulty, especially when POST error message no bootable devices detected.
To confirm go into the BIOS setting and see if the hard drive is detected, if it cannot detect the hard drive then it is definitely faulty.
Replace the hard drive and install Windows on the new hard drive to get the computer working again.
Aug 01, 2009 | Toshiba PSAFGU-058002 Notebook
Compaq c500 blank screen, can heard hard drive running
You should replace the power supply, and clan out dust, and tighten connectors
Mar 11, 2009 | HP Compaq Presario C500t Notebook
Boot up problem..
i dont think the internet files had a difference.
a disk read error mean thateither you have a floppy in your computer or the hard drive is corrupt. that cannnot be fixed so i recomend getting a new hard drive.
Jan 07, 2009 | Dell Latitude D600 Notebook
Blank screen with flashing curser in top left hand corner,
I need a little bit more info.
Do you have a floppy disk in the floppy drive? Remove it. Do you have a CD in the CD drive? Remove it and restart your notebook.
Put your ear on the left side of the track pad. Do you hear any clicking sounds? Do the same for the right side. Do you hear any clicking sounds? If you hear any clicking sounds, and it seems to be constant, you may have a failed hard disk drive.
Try these thing and let me know what happens. Binary Bob
Nov 16, 2008 | Dell Inspiron 6000 Notebook
OS Wont load
You need to reinstall operative system, either using recovery disk, or using a generic windows setup disk.
If the computer does not read recovery disk, then it is probably scratched or faulty.
System reinstall is usually done at any computer repair shop for a not too expensive fee.
When hard disk is damaged you often also hear a typical clicking noise, and system stop shortly after post.
Aug 25, 2008 | Dell Inspiron™ E1505 PC Notebook
Sounds like a hard drive crash. Locate where the hard drive is on your machine and listen closely when you hit the power button. If you don't hear it start to spin, or if you hear any clicking or dull thunking sounds, then the hard drive is shot snd needs to be replaced.
Jun 20, 2008 | IBM ThinkPad R52 Notebook
Qosmio g15 recovery disk error
If the discs are clean and pretty much scratch free, then this is most likely a bad hard drive. If you have another PC or laptop, try burning copies of the recovery cds and then use those. If the problem remains, you will need a new hard drive.
Dec 09, 2007 | Toshiba Qosmio G15 Notebook
Try taking the battery out and use only the AC. If everything turned out fine, it could be a problem on the battery or on the port.
Oct 07, 2007 | Toshiba Tecra 740CDT Notebook
Gateway M675 Laptop Logo
1,151 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
