Question about Gigabyte GA-MA78GM-S2H (rev.1.0) Motherboard
Removing hard drive
How do I remove and replace a hard drive on my laptop.
    Problem Solver:
  • 7 Answers
Hmm well your question is pretty generic... it really depends on the laptop... some have 1 drive, some have 2, some are easy 2 screws, some require pry tools
in general, get the service manual if it's available, as it will have detailed drawings and procedures...
If no manual is available, check the underside of the laptop for icons next to the screws, the harddrive icon could be a little harddrive, or it could be a "can" or a couple of stacked "cans"
Otherwise it might just have unmarked screws or an unmarked access panel, if so, just remove whatever, and take the hard drive out, then put it in.
Posted on Mar 13, 2009
    Problem Solver:
  • 15 Answers
Hi Pawlou, I understand that you want to know how to replace the hard drive on your laptop. I suggest you to please follow the below link for pictorial representation.
http://www.fonerbooks.com/laptop_1.htm
I am sure you will be able to replace the hard drive following the above link as it consists for pictures for your better understanding.
Posted on Oct 26, 2007
Reseat hard drive
The hard drive can be removed and reconnected (reseating) by removing the screw/s on the bottom of the laptop. The hard drive compartment will have disk symbol. Open the laptop lid slightly before you slide out the hard drive. Insert the hard drive back into the laptop so it makes proper connection.replace the screw/s.
Boot up the laptop, if it does not boot up then power off and power up and press F1 to go into IBM BIOS setup - check to see if the hard disk is detected. If not then the hard disk is faulty and needs to be replaced then Windows needs to be installed on the new hard disk to get the laptop operating again.
May 30, 2012 | IBM Thinkpad T43/p Notebook
How to replace hard drive
The Hard Drive can be replaced by removing the cabin of CPU and the correctly remove the Port wire connected to it .And the hard drives are replaced by correctly placing the new Hard Drives to it. if You like my post please make a point for my Answer.
Apr 19, 2012 | Computers & Internet
Removing the back cover
Most of the laptops have a separate cover for hard drives and in your case, you have to locate behind the computer, the cover (in actual size of the hard driver), that is where the hard drive is situated. Or else then you have to remove the whole cover to get access to the hard disk. Take caution when removing the cover, you will notice finger-like structures that are holding the two sides together, make sure you do not break one of them....Again take note of the cables that are connected from the motherboard or anywhere in the laptop to the cover, you really need to take note of those so that you can replace them accurately. If you are not sure of how to do this, then get a computer technician who is going to do this for you...at a cost of course
Mar 16, 2012 | Acer Aspire 4315 Notebook
How do i take out the hard drive on a acer aspire 5552-5686
Follow the bellow link for appart the laptop,
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Removing hard drive:
1. Pull the hard drive to the right side until it's disconnected from the motherboard.
2. Lift up the hard drive.
If you are replacing the hard drive with a new one, you'll have to transfer the mounting bracket to a new drive. Hope this helps, .Reply me for another instruction. Thanks.
Feb 25, 2011 | Acer Computers & Internet
Instructions for installing a toshiba hard drive MK103GAS in a Sony Vaio laptop
Step 1 - Remove Screws Flip the entire laptop over and remove the battery.617_bottom.jpg
There are a total of 4 screws you need to remove as depicted in the red circles.617_unscrew.jpg
Begin removing one at a time.617_unscrew2.jpg Step 2 - Removing the Keyboard After you remove the four screws from the bottom chassis, flip the laptop over and take a look at the keyboard area.
Now look carefully at the top corners of the keyboard, there is a tiny little button that you need to push in order to release the keyboard. 617_keyboard1.jpg
Push both the release keys while pulling the entire keyboard towards you. 617_keyboard3.jpg
Gently lift up the keyboard towards you, while flipping it over. 617_keyboard4.jpg
The keyboard has been removed!
Step 3 - Removing the Palmrest Looking inside, you will need to remove three screws as depicted in the red circles below.617_unscrewhandrest.jpg Next, gently slide the entire palm rest chassis towards you.617_handrestremove.jpg Before you lift the palm rest, notice the delicate ribbon cable on the underside. Then lift it upwards, flipping it over. Be careful not to rip the ribbon cable that's connected!617_handsetremoved.jpgYou now have access to the hard drive!
Step 4 - Removing the Hard Drive Remove three screws from the cage holding the hard drive as depicted below in the red circles.617_unscrewthree.jpg Next, gently remove the SATA cable from the hard drive. It may require a bit of effort to pull the SATA cable from the hard drive, just try to be gentle. Note that there is tape over the SATA cable underneath the hard drive making the SATA cable more difficult to pull out.617_removesata.jpg
Be careful in this step not to rip the ribbon.
The hard drive is now removed!
The next step is to just remove the stock hard drive from its cage be removing the screws on the edges and replace it with the hard drive of your choice. Carefully screw it all back in place, slide the keyboard back in and power on your system! 617_hardrives.jpg
Replacing Toshiba 120GB hard drive 5400RPM with Seagate 100GB 7200RPM 2.5? Hard Drive.
Enter the BIOS by pushing on F2 key during the VAIO boot screen. Ensure the proper hard drive is listed in the BIOS. 617_biosscreen.jpg
Insert your Windows XP or Recovery DVD disc to begin installing the operating system!
if it help full to you please vote me
thanks:ayyunoora
Oct 27, 2010 | Computers & Internet
How do I replace an Asus G50V hard drive
You have to remove the panel on the back to get access to the hard drive. After removing the back panel, you remove the hard drive bracket, remove the old drive from the bracket and install the replacement. You can find the manual for that laptop here.
Oct 16, 2010 | Computers & Internet
Gateway w650i Physically removing a hard drive my laptop help
I ran into this same problem on the exact model laptop. The solution is to remove the two screws that are in the laptop hard drive on the right... Those are obvious... The next step is to remove the two little white space fillers that are to the left of the laptop hard drive on the furthest side from where you removed the screws. That allowed the entire hard drive to now slide to the left toward where those place/space holders were. (don't lose those white pieces) Once you have the hard drive slide all the way left away from the connectors that were holding it in place you can slide up one side of the Hard Drive and easily pull it out!
Apr 08, 2010 | Gateway Computers & Internet
How do you replace a Gateway LT1005u hard drive?
with the laptop upside down there will be a hard drive cover. On most Gateway machines, labels and stickers are often placed on the hard drive panel.
Remove the two screws. MAKE SURE you keep these screws in a safe place
Slide the enclosure out of the laptop.BE CAREFUL and slow as to NOT damage the drive.
Turn the enclosure over. The drive will be screwed to the enclosure. NOTE as This is actually an anti-static container, so again be careful when removing, to avoid static
Remove the screws to actually remove the drive. keep these screws as may be needed for the replacement hard drive
Mar 19, 2010 | Gateway Computers & Internet
When I turn the laptop on (L350) the screen starts with the "Toshiba leading innovation" page then is blank- dark grey. It does not respond to any keys including F2/F12
The laptop can not detect the hard drive please remove the hard drive and then reseat it if the problem persist then replace the hard drive.
Feb 07, 2010 | Toshiba Satellite Pro L350-S1001V Notebook
Computer stuck?
I would try removing the hard drive with the laptop turned off without the power adapter connected. Then reinstall the hard drive and reconnect the power adapter. Check in the BIOS to see if the hard drive is reconogized. If all this fails I recommend replacing the hard drive and reloading the operating system
BPCS
Nov 15, 2007 | Compaq Presario 2100U Notebook
Gigabyte GA-MA78GM-S2H (rev.1.0) Motherboard Logo
378 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
