SOURCE: keurig turns off after making only one cup, when
I just solved this problem with my Keurig Plantnum. It seems that the valve that lets the water in is sensitive to clogs or sticking. Or perhaps like me, you have very hard water and calcium is starting to build up. Anyway, what worked for me was filling the resevoire all the way and turning the unit on. Then while the pump was buzzing I lightly jiggled the reseviore and all of the sudden the water level started to go down.
SOURCE: Keurig stopped brewing, can't even descale because
that happend to mine after only 3 months and when i called to see if they could walk me through fixing it they said they were going to send me a new brewer. try calling them, it must be a problem they are seeing a lot of.
SOURCE: Keurig B66 Elite shut off and won't turn back on.
Had the exact same problem. I called Kuerig, and the shipper me a new one on the spot!
SOURCE: Keurig B70 won't turn on.
Hi, heatman101
Here is a tip that I wrote about how to register your Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
Keurig Registration, User Manuals, Cleaning, and Troubleshooting
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
l;;;;;;;;;;;;;;
