Question about Canon imageCLASS MF6530 Monochrome Laser Copier/Printer
Doesnt print Paper comes out but there is no print on it. The cartiridge is full.
  • 7 more comments
  • Anonymous Nov 26, 2007
    PRINTER DOES NOT PRINT . WHEN TRYING TO MAKE A COPY IT ON COMES OUT AS CLEAN WHTIE PAPER. TRIED CLOSING DOORS REOPENING AND CLOSING AGAIN. SHOULD NOT BE OUT OF INK THAT ONE HAS NOT BEEN IN IT LONG.
  • Anonymous Feb 26, 2008
    Large percent of the time the paper comes out plain when trying to make copies. Toner is okay. All information we got was to clean the contacts on the toner cartridge and inside the machines. My opinion if the machine is working properly we shouldn't have to fiddler with it. This machine is less than 1 year old - is there a replacement program?
  • CrisCat Mar 20, 2008
    After I changed the toner I ran into the same error. I asume lots of people get it because the office down the hall has that same problem all the time. I tried what was recommended and it worked, although I was very unsure of what I was doing. I then tried to be a hero and fix the copier down the hall but I couldn't! Thanks for the assistance but a video of how to fix it would be even better...
  • Anonymous Apr 24, 2008
    All we get is blank paper as well. We have plugged, unplugged, reset the settings, taken the toner in and out. Our copier is a year old, has always had this issue every time the toner is changed. We can usually get it going again, but not this time.
  • ableassistan May 13, 2008
    I have the same problem and only when changing toner cartridges. The repairman came out and said an electrode was bent inside the machine, which happened when taking out the toner. He did not show me which electrode. Today I am having the same problem. It will cost $100.00 for the repairman to be here for five minutes. This is obviously a flaw with the printer - why hasn't Canon posted a solution??
  • Jameelah May 16, 2008
    My image class 6530 spits out blank pages. Copying pages are blank too! The only function that works is the scannert. HELP ME PLEASE!
  • jasonlaw Jun 15, 2008
    does the solution posted really work?
  • nesser522 Oct 28, 2008
    any better advice than the mallot suggestion, please?!
  • cgmk89 Dec 06, 2008
    Paper jammed, pulled out. After that, it gave blank page each time I printed. I looked through all your suggested solutions. I tried four of the suggested solutions, none worked. During the last try, the paper got jammed again. After I managed to pull out the paper, the machine starts working again. I do not know how to solve this. I just got luck.
  • 4 Answers
There may be a much more simple reason :
Reason : the shutter of the laser is not opened by the cartridge. (I had same problem, and solved it). This is a defect of this printer and it results in blank pages. Solved in five minutes. Try it. If it does not work for you, it cannot do any harm.
Open the door and remove the toner. look inside and you will see in the upper part a rectangular window in the metal bar. This window is shut by a metal plate behind when the door is open. Try to raise it with a knife. This is the problem. Now, this shutter is here only for legal reasons (security to prevent the laser beam going out when door open, but when the door is opened the power is shut so...). Cut a piece of plastic just the width of the opening, fold it at angle in the form or an L, then place it on the left side of the opening, so that the shutter can no longer go down. A piece of scotch to fix it in place and you are done.
Now, if it works and you are grateful, I am interested in empty cartridges.If you have some tell me. Thanks.
Posted on Dec 16, 2008
I was able to fix the problem using a combination of the advice above. Being a novice at this, the advice was a little unclear to me so let me see if I can explain what I did in hopes that it will help someone else.
  • Remove the front cover. This is the one that says Canon ImageClass on it. It takes no screws to get this off. Just some gentle/firm pressure. Enough so it doesn't crack the plastic, but enough so it comes off.
  • Then remove the right side cover. Again, some pressure and lifting of the tabs on the bottom/inside is all it takes.
  • Then with a screwdriver remove the three screws that hold the control panel in place on the rightside. The control panel are the buttons that control the scanner. Start button/stop button, etc. The screws will be in the following order... blue tab, metal, blue tab. They are less than an inch all the way across the three screws.
  • To completely remove the control panel you'll also have to remove the 2 screws on the front. There are a bunch of screws on the front, but only 2 hold the control panel in place.
  • When the control panel is free gently slide it out. You'll notice that a ribbon cable is attached. Gently remove it so you can set the control panel aside.
  • You'll notice that when you take the contol panel out, that there is a small triangular panel that sits on the top left of the control panel. It should slide out easily. Remove that and put it aside.
  • Above the control panel and behind is now another blue panel. This is the panel that the paper would sit on when a print comes out.
  • Gently lift the blue panel and you'll see on the left side a black plastic arm connected to a long metal arm. The black plastic piece is about 1"x1". The metal arm is 1/4" x 3". This is the accuator and the laser shutter door.
  • Wiggle both pieces. Make them move in their intended way (rock up/down). One of them will feel sticky.
  • If you can wiggle until smooth, you're good to go. If not, gently run your finger along the metal arm to see if there are any burrs. Be gentle. The burrs are sharp. If you get a burr, remove the arm and file it down. No burrs, just wiggle it, gently bend... move it around until it's smooth. Be very gentle and patient... it comes free eventually.
Hope this helps. Seems to be the only reference on the web to get this fixed.
Posted on Aug 02, 2008
I also had the same problem and today managed to fix it. I am nowhere near an experience printer fixer so I have no idea whether this will work for others, but this no-print issue seems to be pervasive so I thought I would share what worked for me.
Here's what I did:
(1) Turn off and unplug printer.
(2) Open the left cover (this is the door where you put the toner cartridge in).
(3) Remove the toner cartridge.
(4) Using a flashlight, you will be able to see a small rectangular flap or shutter that sits just behind where the toner cartridge normally sits. The shutter might be about 3 inches long and one quarter inch high. I don't know for sure, but I assume that this is the "laser scanner shutter door" referred to by Colbert.
(5) Take a flathead screwdriver and GENTLY insert it beneath the shudder and GENTLY move the shutter up. When I did this there was some resistance and the shutter seemed to be stuck. I moved it up and down a couple of times and it seemed to move easier. I also followed the shutter door over to the right and up a little, where you can sort of see where the toner cartridge arm connects to the arm that opens this shutter. I sort of gently manipulated this arm a couple of times with my screwdriver as well to try to make sure it was free.
I'm not sure if this will work for others, but it worked for me. It only takes a few minutes.
Good luck.
Posted on Jul 04, 2008
I had the some problem. This is what I did to fix it. When you fully open the toner door you'll see a flap that swings down. Before closing the toner door swing the flap to the close position and listen for something that seems to be opening in side the copier. Keep closing the flap till you hear this noise. Close the toner door. Copier should work fine.
Posted on Jul 03, 2008
Okay easy to fix, extremely easy actually. First turn off the copier and remove the toner cartridge. Then look inside and on the inside backwall near the top you will see a metal piece and a small metal flap inside. Use a small screwdriver and on either side see if it lifts. If it does, then the shutter arm has broken, but not to worry. Take a small wad of paper, put a piece of tape on it and jam the ****** in the right side propping up the laser shutter. Make sure the paper wad is small enough to clear the laser glass. Reinstall the toner cartridge after you are satisfied the wad of paper is jammed in that sucka tightly. Close the back toner cart door and it's fixed. Turn the copier on and it should print with no hassles from here on in. Worked on mine :D
Posted on May 26, 2010
Just had the same problem... talked my sweetheart through using the comments that were added here - thought I'd do the same for the next poor soul with this problem.
Over the phone I was able to describe the laser "shutter door" location. She used a plastic zip tie piece to hold the door open...
And got her first copy!! Just in time for the week long conference to start.. thank goodness.
Our experience - definitely the stupid laser door.
Thanks everyone for taking the time to input your comments and work arounds... Thanks Canon for nothing.
Posted on May 03, 2009
We have the same problem at our office every time the power goes out. Our solution: Unplug power from the back of the machine for a few seconds. When you plug it back in, press some random buttons. After that, change the density to as dark as it will go. This, I guess, lets more ink out? Anyway, it prints fine after that. No removing of the control panel or anything like that.
Posted on Dec 02, 2008
Laser Shutter that opens and closes when side door is closed and opened is sticking shut.
Take covers off machine to expose laser unit and open and close side door
and observe metal laser shutter. Remove it and problem solved.
Posted on Oct 31, 2008
This worked for me, but not sure it will work for all. I took a rubber mallet and pounded the printer on the four sides five times each. I then shook the toner three times. I placed it in and opened and closed the flaps twice. I spun the printer around one time and then voila! It was running just fine.
Posted on Jul 16, 2008
The best way to take care of the laser shutter problem is to totaly remove it. theres nothing in there that will tell the machine the toner isent in the machine. this is a perment fix. theres a little more work involved but worth it.
you will need to remove the front cover. control pannel and the eject tray.
Hope this helps
Posted on Jul 11, 2008
OK Guys, I had a slight variation on this problem - -
I also did not get any image printing, even w/ a new toner cartridge.
It seems that the metal connectors that contact the toner cartridge are critical, but my problem was related but, actually lower down than that. There is a little plastic partition that buddies right up with the scanner door flap on the toner cartridge. In my case, the scanner door flap was opening fine, but the secondary flap had a metal contact that was supposed to transmit electricity to a pivot bar that held that secondary flap. All I did was I took a screw driver and pushed the metal connector down so it dragged nicely against the pivot bar - "as it wanted to". I tested it and Voila - It worked. So, the flaw in MF6520 Cannon photocopiers seems to be contacts with and around the toner cartridge, but definitely check all contacts.
Yippeee.
Posted on Jul 07, 2008
You must remove all the covers. Then on the front side.... you can see the arm that actuates the Laser scanner shutter door. It comes off fairly easily . it must be removed then merely file the edges down. A burr develops that needs to be filed down. the edges are really really sharp so be careful. Also I have seen the Arm that opens the Toner shutter door be broken as well.Actually the hinge projection on one side of the toner is what breaks and the arm doesnt swing up quite enough to open the door ... as well as hitting the scanner door.
Hope this helps someone.
Posted on Nov 07, 2007
    Scholar:
  • 121 Answers
When you close the door to the printer, there's something that opens the flap to the laser unit.  This makes it so the laser can shine down on the drum.  The flap isn't openeing when you close the door.  You'll have to look at the flap, and then follow all the mechanisms that eventually lead to the door.  There's a break in it somewhere.
Posted on Oct 27, 2007
  • Eric Engel Oct 30, 2007
    The Toner shouldn't matter too much.  Figure out exactly where the cartridge hits something to open that flap.  Sometimes it works, but it's bent out of shape (if it's metal).  You could try bending it a little (but not too much).
When printing I keep getting lines on my image, all inks are full???
Step First - Alignment, if refilled cartiridge there is air bubbles, pull out all inks by seperated injections & Reriffle, 3- paper setting - photo paper glossy, high quality, & get approx 150-200 sheets photo prints (mention help canon error help E5) your cartiridge not short still working after it, when colors invariants use only plain paper standard quality setting. pls vote
Jul 25, 2010 | Canon PIXMA MP610 InkJet Printer
Fax comes out blank at the receiving fax machine.
This type of fax is "toy" buy a laser fax an get rid of all your problems
May 26, 2009 | Canon FAX-JX200
OFFICE JET 7410 PRINTER
Check the cartiridge if it is sitting nicely on its place. it seems you dint place the cartirdge properly
Apr 02, 2009 | HP OfficeJet 7410 All-In-One InkJet...
The on/off button is flashing. It will not print and flashes up that there is a paper jam, but there is no paper jam
Unplug it from power source and press and hold the power button for few second. Reinstall the ink cartiridges and then restart the the printer.
Sep 17, 2008 | Lexmark Office Equipment & Supplies
Left cartiridge not printing
i've got the same problem. any solutions yet????
May 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Paper jam
Did you look both down the paer feeder, and then nside the unit really closely, in roller, and near cartiridge carriage. Jams can be so very small you can miss them.
Mar 12, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon imageCLASS MF6530 Monochrome Laser Copier/Printer Logo
465 people viewed this question
old marine
old marine
