Question about Mitsubishi WD-Y657 65" HDTV
Tv shuts off randomly - Mitsubishi WD-Y657 65" HDTV
Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Jan 05, 2016 | Televison & Video
I just brought my tv in 3 days ago 55 inch led 240 hz it's just shut off randomly
THE VIZIO XVT553SV has a know problem of random power cycles and random shut offs. It is recommended you call Vizio Technical Support for a proper and permanent solution.
Toll-Free: 877.698.4946 (877 MY VIZIO) Technical Support if you don't get proper assistance at that number call the Executive Office at Phone: 949.428.2525
Jul 18, 2011 | Vizio XVT553SV 55 in. LCD TV
The TV will shut off by itself randomly (anywhere
Sounds like the TV is going into the "protect mode", usually means there is a failure present and it's shutting down to ward off any serious damage to the electronics. The status light will usually blink a error code along with this symptom, call a service center and let them know how many times the light is blinking in a continious pattern and that will help them to diagnos your TV problem. Good luck and Merry Christmas!
Dec 25, 2009 | RCA D52W135D 52 in. TV/DVD Combo
TV shut off randomly. Unplugged for a while, worked for 2 minutes then shut off again.
Hi.
Random shut down can be caused by faulty power adapter, faulty inverter and faulty controller board, add buttons, shorts, bad fan and IR sensor.
The TV must be tested to find out the problem.
I suggest contacting Sanyo by calling the number listed on the owners manual.
Parts and part price available here.
Nov 19, 2009 | Sanyo DP19649 LCD TV
Our 32" Sony Wega CRT TV randomly shuts off. It starts to dim then completely shuts off. This is happening at faster intervals. (Shorter on times)The indicator led blinks 6 times after the random shut...
monitor if b+ voltage normal, if fluctuate check for the power supply area ckt parts for some discrepancy on biasing. if supply normal check on horizontal section area also replace crystal capacitor and check.
Aug 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-34HS420 Random Shut downs
i would say this is a internal problem how long have you had it?
May 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
TV Shuts Off randomly
Our flat panel TV would shut off for 5 to 10 seconds and then come back on. We found out that our Comcast HD box was bad. After a tech replaced the bad box with a good box the problem went away.
Jan 20, 2009 | Televison & Video
Tv randomly shuts off
Replace power relays on power board...
Bill
Oct 08, 2007 | Philips 55PP9401 55" Rear Projection...
Mitsubishi WD-Y657 65" HDTV Logo
16 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
