Question about Dell E193FP 19" LCD Monitor
Dell E193FPC - Screen is getting too bright.
I have this flat monitor for 2 years now, yesterday suddently the screen starts to getting brighter and is not possible to adjust it with the monitors controls.
I was wondering if this has to do with replacing the light inverter.
Any help will be greatly appreciated.
Thanks
    Novelist:
  • 138 Answers
This is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. You check that you can see the image on the screen. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 27, 2008
On my Dell E193fpc monitor, the background lighting goes off after a few seconds. The actual Screen-image is still there (can be seen in bright sunlight). How can I get the backlighting to work proper
This sounds as though there might be a problem with the inverter (this is a component that supplies a high voltage for a tube(s) that illuminate the screen.
As there are high voltages on inverters, this is really a job for a repair shop.
Dec 11, 2013 | Dell E193FPC 19" TFT LCD Flat Panel...
Hello, I have a Dell U2711 monitor that now displays just a bright white screen. I was using the monitor, when it started getting brighter and developed a series of vertical lines in a repeating pattern...
Dell technical support number by dial Dell helpline number 1-80-243-0019 to get Dell customer support services to repair Dell Computer, Laptop, Printer.
Apr 14, 2017 | Dell U2711 27 inch LCD Monitor
My Dell moniter is a 19 inch monitor (Model No: E193FPc) and it's been working fine for 5 years. Now when I plug in the power, the power button goes green, but the monitor shuts off instantly. This...
your LCD monitor has a defective cathode driver inside, it will shut down your monitor when it has short circuit or has defective cathode bulb. you have to open your LCD case to see the circuit .you need screw driver set plus and negative to open the case. if your have knowledge in troubleshooting you can check the circuit if it has a short or defective part at the cathode driver, it has two small transformer that supplying the 2 or 4cathode tube in upper and lower screen of lcd
Aug 18, 2011 | Dell E193FPC 19" TFT LCD Flat Panel...
Screen not bright as normal , how do you make screen brighter?
<Fn> and up-arrow key Increases brightness on the integrated display only (not on an
external monitor).
<Fn> and down-arrow key Decreases brightness on the integrated display only (not on an
external monitor).
Jan 07, 2010 | Dell Inspiron 6000 Notebook
Screen keeps going into darkness at start-up
Hi
The screen kept winking out because the brightness setting was too dark, something to do with the tolerance perhaps?
I just made it brighter and all was well!
Dec 29, 2009 | Formac Gallery Xtreme 2010 20.1" LCD...
Dell Inspiron monitor is hard to see, not as bright
boot and press F2 got to the menu comes up and go to display part in thath where you can increase the display brightness
or press Fn+F5 key while you are in ur OS
Jun 16, 2009 | Dell Inspiron 1521 Notebook
Screen very dim, but set on 100% brightness.
Good Morning! With the 8 years operations of your emachines monitor, some of its electronic parts might incurred cold solder joint connections from its circuit board & possibly some of its Capacitor parts are already worn-out. please try to get assistance from an electronic service technician which will surely diagnose & repair the problem. best regards.
May 04, 2009 | Computers & Internet
Monitor gets brighter
Well... it's time for a replacement. It's seems your AD Board begin slowly to dies out... Eventually will turn to white screen.
You'll need a new AD Board.
Mar 10, 2008 | Fuji FP-768 17" Flat Panel LCD Monitor
Dell E193FP 19" LCD Monitor Logo
88 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
