Question about Toshiba 42H81 42" Rear Projection Television
Toshiba 42H81 self diags operation number 100
Unexpected operation number 100 within self diags. Failsafe circuit intermittently shuts Unit down. Unplugging power, waiting 5 seconds, and plugging back in to recover... How can I determine what operation number 100 is ? note: normal ops is 000 iaw O&M manual.
    President:
  • 4,402 Answers
How did you get that number?
Posted on Dec 19, 2007
A/C runs fine for 7-8 minutes, then shuts off.
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
May 11, 2013 | Sharp Heating & Cooling
It shuts off and blinks 11
AHX18MEV
4 - 12
1. Indoor unit
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
2007 Mercury Mountaineer the eatc will turn off
this is for 2002
Dual Automatic Temperature Control Module Self-Test The DATC module self-test will retrieve on-demand (hard fault) DTCs only, it will not retrieve continuous DTCs. Continuous DTCs can be cleared when exiting the DATC module self-test. Make sure to retrieve continuous DTCs by carrying out the Dual Automatic Temperature Control Module — Retrieve Continuous DTCs procedure before clearing any continuous DTCs.
  • The DATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A scan tool must be used to retrieve these concerns.
  • The DATC module self-test will detect concerns in the system control functions and will display on-demand (hard fault) DTCs for concerns that are present during the self-test. The vehicle interior temperature should be between 4°C - 38°C (40°F - 100°F) when performing the self-test. If the temperatures are not within the specified ranges, false DTCs may be displayed.
  • The self-test can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when the self-test is activated.
  • To enter the self-test press the OFF and FLOOR buttons simultaneously and release, then press the AUTO button within two seconds. The display will show a flashing blower icon for 20 seconds, after which all vacuum fluorescent segments will be displayed if there are no on-demand DTCs present. If DTCs are present the DATC module will display "00 00" and then on-demand DTCs. Record all DTCs displayed.
  • If any DTCs appear during the self-test, carry out the diagnostic procedure. Refer to the Dual Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given.
  • If a condition exists but no DTCs appear during the self-test, GO to Symptom Chart Condition: The DATC System Is Inoperative, Intermittent or Incorrect Operation.
  • To exit the self-test and retain all continuous DTCs, press any button except DEFROST. The DATC module will exit the self-test and retain all continuous DTCs.
  • To exit the self-test and clear all continuous DTCs, press the DEFROST button. The DATC module will exit the self-test and all continuous DTCs will be cleared.
  • Always exit the self-test before powering the system down (system turned OFF). Once the self-test is exited the ignition switch must remain ON for at least 30 seconds to allow the temperature blend door actuators to automatically recalibrate.
  • Continuous DTCs will be deleted after 80 ignition switch ON cycles after the intermittent fault occurs.
Dual Automatic Temperature Control Module — Retrieve Continuous DTCs The DATC module will retrieve only continuous (intermittent) DTCs when carrying out this procedure.
  • Retrieval of continuous DTCs can be initiated after cycling the ignition switch from OFF to ON. Normal operation of the climate control system stops when retrieving continuous DTCs.
  • To retrieve continuous DTCs press the OFF and PANEL buttons simultaneously and release, then press the AUTO button within two seconds. All vacuum fluorescent segments will be displayed if there are no continuous DTCs present. Continuous DTCs are indicated by the presence of the degrees Celsius symbol (°C) on the DATC module display. Record all DTCs displayed.
  • If any DTCs appear, carry out the diagnostic procedure. Refer to the Dual Automatic Temperature Control Module Diagnostic Trouble Code Index and follow the ACTION for each DTC given.
  • If a condition exists but no DTCs appear, GO to Symptom Chart Condition: The DATC System Is Inoperative, Intermittent or Incorrect Operation.
  • To exit and retain all continuous DTCs, press any button except DEFROST. The DATC module will exit the retrieve continuous DTCs mode and retain all continuous DTCs.
  • To exit and clear all continuous DTCs, press the DEFROST button. The DATC module will exit the retrieve continuous DTCs mode and all continuous DTCs will be cleared.
  • Always exit the procedure before powering the system down (system turned OFF). Once the procedure is exited the ignition switch must remain ON for at least 30 seconds to allow the temperature blend door actuators to automatically recalibrate.
DTC Description Action Diagnostic Tool Display DATC Module Display B1251 1251 Air temperature internal sensor circuit open Go To Pinpoint Test A . B1253 1253 Air temperature internal sensor circuit short to ground Go To Pinpoint Test B . B1255 1255 Air temperature external sensor circuit open Go To Pinpoint Test C . B1257 1257 Air temperature external sensor circuit short to ground Go To Pinpoint Test D . B1259 1259 Solar radiation sensor circuit open Go To Pinpoint Test E . B1261 1261 Solar radiation sensor circuit short to ground Go To Pinpoint Test F . B1342 — ECU is defective INSTALL a new DATC module. B1676 1676 Battery voltage out of range CHECK circuit 729 (RD/WH) for a fault. If okay, REFER to Section 414-00 to diagnose the charging system fault. B2266 2266 Left side blend door circuit failure Go To Pinpoint Test G . B2267 2267 Right side blend door circuit failure Go To Pinpoint Test H . B2267 and B2268 2267 and 2268 Left side and right side blend door circuit failure Go To Pinpoint Test I . B2268 2268 Steering wheel climate control circuit open Go To Pinpoint Test J . B2269 2269 Steering wheel climate control circuit short to ground Go To Pinpoint Test K . B2477 2477 Module configuration failure RECONFIGURE the DATC module. REFER to Section 418-01.
Mar 01, 2010 | 2007 Mercury Mountaineer
Toshiba model 42H81 projection tv receiving blue and yellow shadows on screen.
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS and all it resistors.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 06, 2010 | Toshiba 42H81 42" Rear Projection...
Code 24 and 25 (blend door actuator)are showing up
yes, IP must come out.
Actuator —Electronic Blend Door Removal
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Remove the instrument panel. For additional information, refer to Section 501-12 .
  1. Disconnect the connector
But, you sure it's the blend door actuator?
Electronic Automatic Temperature Control Module Self-Test
  • The EATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A scan tool must be used to retrieve these concerns.
  • The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4°-32°C (40-90°F) when carrying out the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed.
  • The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
  • To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
  • If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
  • If a condition exists but no DTCs appear during the self-test, refer to the Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
  • To exit self-test and retain all intermittent DTCs, push the blue (cooler) button. The control will exit self-test, retain all intermittent diagnostic trouble codes and then turn OFF (display blank).
  • To exit the self-test and clear all DTCs, press the DEFROST button. The vacuum fluorescent display window will show 888 and all function symbols for one second. Then, the EATC control assembly will turn OFF (display blank) and all DTCs will be cleared.
  • Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
Connect a fused jumper wire between EATC module C228 pin 26, circuit 246 (VT) and EATC module C227 pin 2, circuit 54 (LG/YE). Connect a second fused jumper wire between EATC module C228 pin 13, circuit 245 (BN/LG) and EATC module C227 pin 3, circuit 57 (BK).
  • Does the actuator motor move in the clockwise direction?
sya~us~en~file=arrow.gif~gen~ref.gifYes GO to A2 .
sya~us~en~file=arrow.gif~gen~ref.gifNo GO to A3 .
Jul 02, 2009 | 2000 Mercury Grand Marquis
Question regarding toshiba 42h82 not 42h81
This is like a quiz right?? Let's see ;;;;;;; by convergence resistors I assume you mean the yoke return resistors out in front of the amps. There are 6, in the 2.2ohm 1w range, easy enough to find. The value of the convergence amps, that unit uses two stk392-110 Sanyo original Ic's rated at 6amps. You can use stk392-150's or stk392-180's just a higher amp rating. The two pico fuses in that circuit are F851 and F852 respectively.
Hope I get an "A"
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Sep 24, 2008 | Toshiba 42H81 42" Rear Projection...
Red power light on a Toshiba CE 32 T 11 is blinking and unit will not come on
I had the same problem with the Toshiba 42H81 rear projection TV and the power supply circuit board had to be replaced.
Aug 20, 2008 | Televison & Video
Convergence
you can replace these your self if you can solder and are mechanical. there are two stk ic attached to a silver heat shield
You can call or on line give them the model number and tell them you are looking for the convergence ics The part store .com
www.partstore.com
Be careful unplug if it looks to hard please call your local tv shop the fix for a shop is around 250.00
Thanks doctor video
May 20, 2008 | Toshiba 42H81 42" Rear Projection...
Where can i get a Screen for toshiba 42pw33p model ??
The model number 42pw33p is not a valid Toshiba model number. However, 42H81 is a valid number. The listing below is for model 42H81 ONLY! Double check you number before purchasing.
There are 3 screens that make up the screen assembly The inner screen is the Fresnal Screen. The middle screen is the Lenticular Screen and the outer screen is the Protective Screen. Please click on the links below to purchase these items.
Fresnal Screen
Lenticular Screen
Protective Screen
Mar 06, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
