Question about Texas Instruments TI-86 Calculator
Standard deviation It has been so long since i've used my calculator that i forgot how to do standard deviations on them...can you help?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
1. Put the data into a list.
2. OneVar list will produce a screenful (and more) of one-variable statistics.
OneVar is available through the STAT CALC menu. "list" in step 2 is the name of the list created in step 1.
Posted on Jan 19, 2010
How to calculate standard deviation
My name is adieh. Hav a great day.
Here are the tips on how to calculate standard deviation using a graphic calculator:
1. Turn on your graphing calculator, go to the stats/editor screen and enter your data set into list1. Once this is done, return to your home page by hitting the home button.
2. Push the catalog button and scroll through the applications until you find "stdDev(". Place the arrow next to it and press enter.
3.Type the word "list1" into the open parenthesis. After you have put that in, close the parenthesis so you calculator doesn't show an error message.
4. Press the enter button. The calculator has done the calculations and you now have the standard deviation of your data set.
Note:
Using 1-var stats in the stats/editor screen will also give you the standard deviation. Using that function will also give you other information associated with your data set.
Hope it helps.
Thank you for using fixya.
Sep 23, 2011 | Texas Instruments TI-84 Plus Silver...
How do you find standard deviation on the calculator?
Press 2nd [CSR] (shift-7) to clear the statistical registers. Use the Sigma+ key (just above STO) to enter data points. Use 2nd [Sigma-] to remove erroneous data points. Use 2nd [sigma x n] (shift-divide) to compute the population standard deviation, or 2nd [sigma x n-1] (just to the left of the previous key) to compute the sample standard deviation.
Jun 07, 2010 | Texas Instruments TI-30XA Calculator
How do I use the standard deviation function?
  1. Calculator must be in SD mode (standard deviation mode) :Press [MODE] [.]
  2. However, if [FIX] or [SCI] appears on display you must press [MODE][9] first.
  3. Data input always starts with [SHIFT][SAC], to clear the registers of old data.
  4. Type a number and press the [DATA] key, it is the [M+] key at the bottom right of keypad.
After you finish entering the data
Press [SHIFT] [9] (sigma n-1) to get sample standard deviation
Press [SHIFT][8] (sigma n] for the population standard deviation
Press [SHIFT] [7] (xbar) for the mean
Press [SHIFT] [6] (n) for the number of data entries
Press [SHIFT] [5] (capital sigma x) for the sum of values
Press [SHIFT] [4] (capital sigma x to y) for the sum of squares of the values
For additional information you might consider taking a look at the calculator manual.
Apr 30, 2010 | Casio FX-260 Calculator
Does this calculator comes with a standard deviation or population standard deviation button
Yes. The sample standard deviation is 2nd [sigma x n-1] and the population standard deviation is 2nd [sigma x n].
Apr 02, 2010 | Texas Instruments TI-30XA Calculator
Is there a formula for standard deviation problems
Of course there are formulas for those calculations. You find them in books on statistics. Do not worry, the calculator has been programmed to use them. All you have to do is learn how to get the calculator to give you the results.
If you still want to see the formulas with your very eyes, I suggest you go to the local library, ask a math teacher, an accountant, or launch a Google search for them.
Hope it helps.
Aug 05, 2009 | Casio fx-300ES Calculator
How to do standard deviation calculations?
M=500 and S=100 in a normal distribution, what percentage of the subjects have scores between 400 and 600
Jun 03, 2009 | Casio Office Equipment & Supplies
Standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
Oct 05, 2008 | Casio FX-115ES Scientific Calculator
Standard Deviation
I want to calculate a standard deviation on BA II plus
Apr 23, 2008 | Texas Instruments BA-II Plus Calculator
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
Nov 15, 2007 | Texas Instruments TI-86 Calculator
Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Sep 07, 2006 | Casio FX-7400G Plus Calculator
Texas Instruments TI-86 Calculator Logo
153 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
